Intake manifold gaskets |
MourningWood ![]() Gold Member ![]() Joined: June-13-2014 Location: NorCal Status: Offline Points: 920 |
![]() ![]() ![]() ![]() ![]() Posted: October-24-2021 at 10:29pm |
Just taking apart PCM Ford 351W engine from '94. Found molded rubber end seals for the intake manifold. They sort of clamp-on to the rail. Never seen/used these before, but I like them. Original? Where can I get a set? Thx.
'I measured twice, cut three times, and it's still too short!" |
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3010 |
Post a pic or 2 of the gaskets in question. From your description, they don’t seem to be OEM standard gaskets. www.skidim.com and www.NautiqueParts.com have ‘em.
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11197 |
Doesn't do you any good, but they're easy to find in some Chevy gasket kits and some 302 Fords have them too.
One possibility would be Mahle MS 15942 and another would be FelPro MS 96025.............they might have the rubber end seals.........maybe link
They show rubber end seals, but some packages come with a couple tubes of RTV instead of the rubber seals. ![]() |
