  New Posts New Posts RSS Feed - Trans fluid, Suck or  Drain?
79Tique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Topic: Trans fluid, Suck or Drain?
    Posted: April-18-2008 at 3:03pm
Hey guys I'm looking for some advice from some one with experience with boats like mine.
On my 79 Tique draining the trans was pretty easy. I traded to a 94 Nautique this winter and there is no space around the trans. Looks to be a pain in the ass to drain. So I'm thinking I'm going to suck the fluid out. Is there any disadvantage in doing this? Also any good advice on the way top do it?
Thanks,
Gabe
Work to live, not live to work.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2008 at 5:01pm
Tique, get the trans to op temp, then fill completely to the top with fresh oil, fire the boat again and let the old oil circulate with the new.   remove the line that goes to the cooler and put in a bucket and fire the boat again and wait for the oil to stop coming out. then re-install the line
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: April-18-2008 at 11:46pm
That sounds like it could be messy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 1:07pm
Thanks for the advice Eric. Is it messy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 1:25pm
key word:   bucket, make sure you hit it, actually the oil doesnt come flying out its a pretty good stream but not what you would think.
I can only make a suggestion like your mom when you were a kid, make sure you dont miss the toilet, i find myself telling my son that come to think of it
ripsaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ripsaw Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 1:31pm
So are you saying that sucking it out is not a good thing, or just not as thorough as using the cooler line. Good stuff eric, I've never heard that aproach. Sounds a little like the old farmers used to say about putting on a new oil filter and running it with the old oil for a while then change both.
86 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 3:15pm
sucking it out is also a good idea, once again i went to a job 2 hours away and left my pump at the shop, so i figured you know what? im going to remove the hose and fire the boat and have been doing it ever since, I still use my pump but on some of the bigger boats they will have 10 gallons of oil in them and using the transmissionn pump is the way to go
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2008 at 11:04pm
I'm going to give it a try. Eric do you have a trans fluid you recommend?
Note I'm not working on the boat in the picture, the one I'm working on is my 94 Nautique.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2008 at 12:34am
I've always sucked the fluid out.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2008 at 12:14pm
Tim, you cant use a Johnny Holmes super sucker for this   lol
Dexron Mercon
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-20-2008 at 7:14pm
Got it.
Thanks again for the help.
wakesurfer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakesurfer Quote  Post ReplyReply Direct Link To This Post Posted: April-28-2008 at 9:44pm
Hey guys!
I have a velvet drive trans in my 77 ski nautique and it seems to want to stay in gear even in neutral...
It spins a few revolutions a second... as if in gear.
Is this a trans fluid issue also, or something else?
Any disadvantage to sucking out the fluid and replacing with NEW fluids?
Jamie
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2008 at 4:36am
Jamie,
This is what Eric recommended to me and he is probably the most knowledgeable person on the transmission stuff on this site. I think it's OK to suck it out as well, but you should warm the trans up first and do the over fill thing Eric mentioned above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79Tique Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2008 at 4:39am
I've heard it common for these transmissions to turn the prop a bit in neutral, but I'm not sure if means something is out of adjustment.
Eric do you have the answer to that one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2008 at 10:30am
I look at it this way, if you happen to leave the boat running and your kids foot is under there will the turning prop cut his foot off or will it stop?
no adjustments only when setting up the forward pack on assembly
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-29-2008 at 10:33am
they will drag a bit when cold, or when you rev the engine, but in reality you should have a nice clean nuetral...it is also unsafe if you cant get it to stop turning and there is no adjustment as i said a second ago
