1994 Ford PCM 351HO ENGINE |
righterjc ![]() Newbie ![]() Joined: October-04-2004 Location: United States Status: Offline Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: November-29-2004 at 2:21pm |
complete 1994 351HO engine from top to bottom & front to back. needs #2 valve replaced and has a very very very small chip on #2 piston,ProTec management system, manifolds, holly carb, was running great but needs new valve, gt40 heads,800 hrs, $1000 or obo
CALL 714 745-3267 or e mail me at righterjc@sbcglobal.net, Pics now available. |
workky ![]() Guest ![]() |
was this engine used in salt water?Do you have a picture?
righterjc ![]() Guest ![]() |
Fresh and salt, my mechyanic said it was in good shape. I will have pic's tommorrow.
righetrjc ![]() Guest ![]() |
I have pictures available. E-mail me at righterjc@sbcglobal.net for pics
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
is this the engine that hydrolocked in the #2 cyl? that was posted before?
Im not sure what hydrolock is ,I have two fuel tanks on my correct
craft and I usually run from my rear tank, I switched to my front tank and my mechanic said my front tank had bad gas in it which tuliped the #2 valve . I Switched back to my rear tank and with the newer fuel and and changed the spark plug and it seemed to run fine except there was no compression on the #2 plug per my mechanic, He said there was a very very small small chip about 1/2 the size of a sunflower seed on the #2 piston. He said I could still run engine with just a valve job and it could run for a long time or I couild do a rebuild. But I had a chance to put in a 1999 PCM so I went for it. |
