rudder... |
Author | |||
82wake2001
Senior Member Joined: February-14-2008 Location: United States Status: Offline Points: 240 |
Posted: May-14-2008 at 4:56pm |
Ok i have the steering cable replaced and its like butter. Now i have water coming in from the top of the huge nuts that attached the rudder to the steering cable. I have also noticed the rudder moves up and down about 2 inches if I move it by hand. i have tried to adjust the collar and the locking nut with no luck does anyone have any material showing hoe the housing is assembled?
Joe
1982 ski nautique 2001 "Lady of the Wake" |
Joe, You need to repack it just like you would the stuffing box on the prop shaft. It should take the 1/4" packing that Skidim sells or any marina. There are several good threads on the procedure. I'll see if I can find one and get back.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
I wouldnt make that assumption. My '90 took 3/16". Id pull the old stuff out or measure the packing gland first to be sure. |
Tim, On the rudder too? |
Quigs85SN2001
Groupie Joined: September-30-2006 Location: Davisburg, MI Status: Offline Points: 67 |
My '85 takes 3/16" on both the rudder and prop shaft.
Brian
Yup. |
David F
The up and down movement is normal and acceptable. You could try tightening the packing nut.
88 Nautique
Senior Member Joined: September-20-2006 Location: United States Status: Offline Points: 221 |
Same with my 88. Just ask them at Skidim. They'll know. |
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
Just called and Skidim told me is 3/16 on both. Well, at least on a 87 SN.
