  New Posts New Posts RSS Feed - space in a 79 nautique
CC 79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CC 79 Quote  Post ReplyReply Direct Link To This Post Topic: space in a 79 nautique
    Posted: December-21-2004 at 5:36pm
Hi, anyone know if the shelves running down the sides of the 79 nautique are neccesary? I need the space for fat sacs and would like to cut them out. Wondered whether anyone has done this or if anyone knows whether they are structualy important, i cant see that they are.
Any advice?
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-21-2004 at 6:52pm
They are not structually important and where optiontional from the factory. I've seen several without them and several with them. The vertical panel is screwed on as well as the rear vertical panel in front of the gas tank. It shouldn't be that hard to remove just be care when trimming the shelve that is glassed to the side of the haul. Grind to much and you have a soft spot on the side of the haul. It doesn't have to be perfect because it will be cover by carpet and you could add filler to get it smooth before apply the carpet to the sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-21-2004 at 6:57pm
Also you will only gain about 6-7 inches total extra width at the bottom and maybe 7-9 inches where the self was. keep in mind the the sides have a slope to them so it is narrower at the bottom where the floor meets the sides verses where the selves meets the sides.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CC 79 Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2004 at 5:09pm
Cheers mate
