  New Posts New Posts RSS Feed - 460???
460???
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: 460???
    Posted: May-13-2009 at 10:02am
any leads on a mid 80's blue boy? cant see any cracks but filled to the rim with water. never cracked into one,
they fired the boat in March and never re-winterized they say, but i dont think it got cold enough to crack the block....thin manifold ? anything else to look for?
many blue themed nightmares lately
86BFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 86BFN Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2009 at 2:38pm
Eric, are ready to come back to the other side now? LOL
👣 Steve
86 Barefoot Nautique
89 Martinique
Former Owner: 93 Hydrodyne 350 MAG
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2009 at 2:42pm
Eric, I'm probably not telling you anything, but I have seen a couple of 351 intakes that were cracked at the bottom of the thermostat housing.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2009 at 5:26pm
me too, the gt-40 that chesslovesmammarys is getting was cracked about a half inch,i wouldve hated to be the poor Bsterd that paid that bill, real thin under the thermostat housing and thats what i suspect.
BTW Steve, when a paying customer rolls in with a BBF, my reply is no better engine out there   lol, i have been itching lately and its not from glass, alergic reaction?
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-13-2009 at 11:57pm
Eric, would you happen to have the manual with the crankshaft specs on the Mercruiser 470 engine???
That's another itching engine out there!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2009 at 10:13am
im not familier with the 470, what exactly is it? I have close to 1000 manuals, those specs are in there somewhere.
Greg, I popped the thermostat housing and it still had water in it from when they fired the boat, the block is filled halfway with mix oil/water any cracks would allow the thermostat housing to be empty, hopefully the engine will be out by the time i get to work and I'll pop off the intake, it didnt get cold enough to crack...this one is screwy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2009 at 10:27am
It'll be interesting to see what you find. I found the crack right where the front rails mate. I only found it because I was chasing a weep of oil down the front. Since I have seen the same oil leak on a couple of others.
I would only get a tiny bit of water in the oil, so maybe intake water ports?
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2009 at 10:32am
it has to be going in through the valley, but why is the intake still full of clean water? unless it is a slight crack and pisses under pressure
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2009 at 10:49am
Maybe someone topped off the radiator?
Ya never know...a friend of mine pumped 200 gallons of gas into a rod holder 1 time...
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2009 at 5:49pm
Now that's too funny!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2009 at 8:51am
problem pretty much solved, while the engine hung on the gantry, over a three day period clean water constantly dripped out of the bell housing onto the floor....guess why
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: May-21-2009 at 2:13pm
it doesnt have the cooling plug in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2009 at 10:06am
The boat filled with water and now im in a battle with the owner and the seller, the new owner doesnt know who to believe so i set him straight yesterday. the boat was brought to me this way. I popped off the bellhousing and can see a nice rust line about 2" above the crank centerline,
I told the new owner, what exactly do I have to gain here? its here because your friend reffered you...sometimes id just like to smack guy's like this upside the head, he just doesnt get it
