  New Posts New Posts RSS Feed - Boat Cleaning
Boat Cleaning
ski4069 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ski4069 Quote  Post ReplyReply Direct Link To This Post Topic: Boat Cleaning
    Posted: December-02-2009 at 12:04pm
What is the best method to clean the outside of the boat to get the yellowish stain off from the water in our lake? Is there something homemade that works out great?
Thanks
Jared
Go to heaven ski like hell
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 12:28pm
Some people are happy with a homemade concoction of 50/50 Lysol toilet bowl cleaner and hydrogen peroxide. Personally, I havent found anything (home made or not) that can touch Marykate On/Off hull cleaner. Its super strong and acidic, but works like magic with no scrubbing, even when diluted. You can find it at West Marine or online. Just be sure to wear junk clothes and eye protection... and dont let it sit very long on painted surfaces (like the trailer).
Post Options Post Options   Thanks (0) Thanks(0)   Quote ski4069 Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 2:42pm
Thanks, I'll try it
Bigcity View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bigcity Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 3:01pm
Our boat spends the summer May - October in the river near the ocean in brackish water. After a few weeks the hull gets real green.I try to pull it once through the summer to cleanand wax the hull and change oil etc and have found that FSR ( any marine store) works great. She cleans up like new. Good Luck.
BIGCITY
My Baby !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 3:15pm
Find a janitorial supply house and buy toilet bowl cleaner. You will go broke buying it any other way!!
Tim
harddock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote harddock Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 3:38pm
There is a jel called FSR (fiberglas stain remover) You apply it on with a brush or rag, let it sit 5min and wash it off. The area will need to be waxed but it works well.
There is also a similar product called Y-10.
There is a concentrated powder that you mix with water called Slimy Grimy. This is more for cleaning a dirty scummy hull than just the stain.
Should be able to be purchase any of theseat marine stores, or boat dealers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 3:41pm
Different cleaners (chemicals) work better on different build ups on your hull. What works good for tannins in Wisconsin might not be as successful removing algae in Florida.
Definitely rinse your trailer well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: December-02-2009 at 4:13pm
I think if all of these chemicals were examined you would find that they are all acidic. I will grab the toilet bowl cleaner out of the closet and post later on what it is.
+1 on the trailer. Wish I had pics of what mine looked like before I painted it.
Tim
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-03-2009 at 11:16am
+1 on the toilet bowl cleaner but heed the warnings fully. This stuff is caustic and will ruin trailer paint but far more important is to wear rubber gloves and eye protection. Rinse your skin immediately if you get any on yourself, it burns, I know.
I just cleaned my 81 this fall before putting it away but I removed it from the trailer. My hull was filthy but the Toilet bowl cleaner (The Works) took all the staining off without any scrubbing. Give it a few minutes to work and rinse it off. DO NOT get it on any painted surfaces or your trailer bunk carpeting.
WhiteLakeSkier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WhiteLakeSkier Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2009 at 7:44pm
on/off. Not the gel stuff. Put the liquid in a pump up pesticide sprayer and spray on. Stay clear of the mist though, you might melt!
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2009 at 8:12pm
I use the 'Works' TB cleaner. A good time to do this is when the boat is off the trailer.
I use a brush mounted on a 3 ft long broomstick.
Not much leverage, but at least you can keep that acid off your arms!
