  New Posts New Posts RSS Feed - Engine ID and vacuum check
mustang65 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mustang65 Quote  Post ReplyReply Direct Link To This Post Topic: Engine ID and vacuum check
    Posted: June-12-2010 at 3:24pm
Where would the engine ID stamp be on the 351 (82SN)?
Also, where is the best place to connect the vacuum gauge? The pcv valve? Thanks!
davidg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davidg Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2010 at 3:47pm
Not sure about the engine stamp. However, on the vacuum question, there is a hex head bolt/screw at the back center of the intake manifold (behind carb). I hook mine up there. I believe that is a good spot to tap in to get a good vacuum reading.
I would be interested in hearing what kind of reading you get. Also, make sure your engine is warmed up first. You will get a better/more accurate reading.
horkn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote horkn Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2010 at 3:55pm
If the stamp is like mine, then it is on an aluminum tag bolted to the intake, aft of the carb.
