  New Posts New Posts RSS Feed - Steering wheel
Steering wheel
rithmetic man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rithmetic man Quote  Post ReplyReply Direct Link To This Post Topic: Steering wheel
    Posted: August-10-2010 at 7:18pm
Does anyone have a '60's era Correct Craft steering wheel that they could part with?
"Life is hard; It's harder if you're stupid...Pilgrim..."
John Wayne
1965 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 10:18pm
You'll have to keep an eye out on ebay,hard to find but they are out there.There were at least 4 different ones in the '60s
Post Options Post Options   Thanks (0) Thanks(0)   Quote rithmetic man Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 10:27pm
Thanks Gary, I found one on there but they wanted about 119.00 for it. I hate to spend that much but I may have to.
John Wayne
1965 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 10:32pm
Wayne,I hear you. I paid about that for mine on ebay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 10:42pm
That one your looking at is it from Michigan? If so thats not a '60s wheel, it's a 70s one
Post Options Post Options   Thanks (0) Thanks(0)   Quote rithmetic man Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2010 at 10:45pm
That probably is the one with the slots in each spoke. I do not know what that era looks like then.
John Wayne
1965 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 1:48am
Here is an early one
Then you have this one which seems to be the one used the most.
Then there is
this one seems to be only on the real late 60's
And finally this one used on SS models till 68,69ish before they went to the above one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 10:50am
Nice run down, Gary. Ive also seen a handful of these, which seemed to be used more on the Ski Nautiques and larger boats in the mid-late 60's.
The 3 spoke white with the chrome overlay and fake woodgrain underneath is definitely the most common, at least on the 67-71 boats. Some Mustangs and Barracudas (especially the SS) got the woodgrain one that you have as an upgrade. All of them can be tough to find!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rithmetic man Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 11:29am
Excellent research. I would think that with that many options for wheels from that era that they would pop up more often. You have certainly put me on a better path to find what I need. Thanks for the work.
John Wayne
1965 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 5:19pm
Does anyone know of a good puller to remove one of these older plastic wheels? I picked up a puller kit at NAPPA, but it's not exactly what I want. I think I should have a disc to put behind the wheel to hook onto rather than just attaching the arms to the edges of the plastic wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rithmetic man Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 6:27pm
Bruce we really had a tough time getting the wheel that I am using off the donor boat. We ended up heating the column and eventually wrestled it off. It also had a plastic housing that will definitely deform if you get too much heat in one place. I would think a 4 prong puller with a metal plate behind the wheel with a little heat would work better than what we did.
John Wayne
1965 Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-11-2010 at 9:40pm
Interesting Tim,I have never seen one of those.As for a puller you need something like this Harbor Freight has them too.Then you get a plate,cut a slot in it the width of the steering shaft,drill a couple of holes to put the puller bolts thru and use that to pull against the whole hub of the wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: August-12-2010 at 2:30pm
Gary, I've got the puller. I was hoping they came with a plate, but it appears that is a custom item. Where's a good place to get one of those, a machine shop?
