  New Posts New Posts RSS Feed - Perfect prop?
Perfect prop?
Jimbodawg View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbodawg Quote  Post ReplyReply Direct Link To This Post Topic: Perfect prop?
    Posted: July-08-2005 at 8:15pm
What's the perfect prop for a 79 Ski Tique. I'm not sure what's on it right now. 4 blade??? What pitch, etc???
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2005 at 8:18pm
Um, perfect for what?
River Rat to Mole
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimbodawg Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2005 at 8:26pm
Well...skiing
or "power boating"
or mixture (skiing, wakeboarding, pulling tubers, etc)
or whatever...what is YOUR preference...I'm just looking for feedback/input from various sources.
thanks
ultrahots View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrahots Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2005 at 10:06pm
Just bought a ACME 3 blade and am on the way out to test it.I will let you know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrahots Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2005 at 1:23am
The ACME 3 blade is a really nice prop.A little noisy (on decel especially) has a ton of hole shot power and just a tad slower than my 4 blade OJ at 47MPH (GPS) I think the noise comes from the CUT they put on it.Anyone else with a ACME hear this ? My OJ is a perfectly quiet prop but did not have the out of the hole power and just raw umpfhh of the ACME.Hope this sheds a little light on it for you.
surroundsound64 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote surroundsound64 Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2005 at 3:41am
Man I hear all this talk about a different prop. hehe. I love my factory prop. When my uncle had this boat (with this prop) he pulled 9 skiers out of the water at once (on video tape). I can't understand why people are always wantin to change props! hehe
1981 Ski Nautique
2000 SAN
Looking for a 2000-2006 SAN
Post Options Post Options   Thanks (0) Thanks(0)   Quote ultrahots Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2005 at 4:25am
My boat when purchased was missing the good ole original prop and i destroyed the 4 blade OJ a week ago at the landing.While waiting for my new prop to arrive and the old one to get fixed i used an original type and let me tell you i am glad to get it off the boat.It was a non balanced vibrating machine and made a lot less torque and high end than BOTH of the aftermarket props i have used.If my boat had not come with an aftermarket prop i would have never known.
Terry
882001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 882001 Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2005 at 1:27pm
true dat. the stock prop is awful. sounds like you are looking for the acme 540
a article keith wrote http://www.correctcraftfan.com/articles/ACME_540_Prop.asp
Alf View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alf Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2005 at 4:46pm
I'm looking to replace my stock prop on my 86 Martinique. I'm a boarder...and that's all I do. So i'm thinking about going with a 12 pitch. What's the pros and cons of going with a 4 blade?
Jeff View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2005 at 6:14pm
I'm not going to say that the after market props aren't more refined, but don't be so quick to toss the original Federal, Michigan, whatever. My '89 came new with a Federal, that was out of balance and the blades didn't track. The boat shook like hell. An afternoon at the prop shop and the prop and boat ran very smooth. I'm guessing mine was dinged during shipment, because I can't see Correct Craft releasing a boat after their 1 hour check ride, that had a vibration problem.
If it's noisy or vibrates, get it checked. If you still don't like it, happy shopping.
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: July-20-2005 at 12:35pm
Jimbodawg,
Your Tique came with a 12x14. I've run several different brand and size props on that same hull in a Mustang, including Federal 12x13, 12x14; OJ 12x13 and 12x14. The lower the pitch, they definitely had more low end grunt, but turned above the recommended WOT range, although the 12x13 OJ is comparable to a 12x14 Fed rpm-wise. I will be testing a special ACME 540 13x12 that they cut down slightly on the diameter to fit better. The std 13x12 roared loadly from being too close to the hull according to my SN dealer, and slowed the boat slightly compared to my otherwise favorite 12x13 OJ. Marshall Morgan's posted 1970 Mustang is running this prop currently, but unfortunately we didn't get apples to apples testing as it was added during engine upgrades.
ReidP
1973 Mustang
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: July-21-2005 at 11:28am
Acme 542, 13" by 11.5 pitch. Just installed a month ago and put about 30 hours on her....great purchase.
64 Skier
66" HO VTX and 67" HO Triumph
71CC
