  New Posts New Posts RSS Feed - Floor help/Fiberglass/Resin guys
98motorsport3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98motorsport3 Quote  Post ReplyReply Direct Link To This Post Topic: Floor help/Fiberglass/Resin guys
    Posted: February-19-2011 at 8:08pm
I posted this over on the2001 as well to try and get as much info as possible.
Hey everyone,
I'll start off with saying I know that I for the most part have rot in my stringers. The motor area is fine but I know some water has gotten into them. Here is the thing, I want to get two more seasons out of this baby before I do a total resto with new stringers/floor and what not. I understand this will not in any way be a permanent fix, and I'm not looking for it to be. Just don't want to do even more damage than has been done or at least keep it to a minimum. That being said here we go.
I have floor separation on both sides of the boat. Drivers side runs beside the seat. Pass side is by the observers seat and down the side a foot or less. The pass side separation seems to be more on the side than the floor. Here are some pictures to give you an idea. Sorry for the crappy quality.
Here's my questions. How should I patch this? Grind out lifted pieces and reglass? Lay glass over the separated area? Fill with resin? I don't know much about fiberglass or resins but I am a performance tech/fabricator for a shop so I pick up on things pretty quick. For those of you who have done this work what do you think is my best option? Also since I will be recarpeting with some lowes/home depot carpet should I roll some epoxy onto the floor to smooth it out and maybe help stiffen up the areas that are patched?
Thanks guys! I promise in the next season or two I'll do the big resto, but it's too close to the start of the season here to try that now.
Here are the pics.
Drivers side
Pass side
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2011 at 8:48pm
Grind down to the glass fibers & put 3 or 4 layers of glass cloth & epoxy over the crack. Each layer 1 inch wider than the last.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98motorsport3 Quote  Post ReplyReply Direct Link To This Post Posted: February-19-2011 at 8:55pm
Excellent!! Thanks. Does it matter which type of cloth/resin I use? Also would it be a bad idea to run a thin coat of resin over the floor before re carpeting? I read something about some that self levels?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98motorsport3 Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2011 at 12:05am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2011 at 11:02am
Nelson, for what you are wanting to do I wouldn't cover the floor in resin since you say you are going to do a stringer job in the next couple of years. You will need to use an polyester resin to do the repair and unidirectional fiberglass cloth. I don't think you need to use mat cloth as your just trying to buy a little time before you do it right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 98motorsport3 Quote  Post ReplyReply Direct Link To This Post Posted: February-21-2011 at 9:36pm
Arg, hmmm I bought fiberglass cloth from home depot, and the resin and hardener. I didn't know there was a unidirectional cloth... the stuff I got just looks like well woven cloth. I'll skip the resin on the floor then b/c I do plan in the next two years on a total make over.
Keep the help coming guys!
Thanks a bunch!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morfoot Quote  Post ReplyReply Direct Link To This Post Posted: February-22-2011 at 11:53am
Nelson, the woven cloth will work okay. I suggested unidirectional as it will form better than woven. Woven will be okay you may just have to "convince" it to stay in place once you wet it down with resin a little harder than you would unidirectional. You'll be okay. Just apply your cloth like Chris suggested.
