  New Posts New Posts RSS Feed - 2 of us need Damper help
mdvalant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Topic: 2 of us need Damper help
    Posted: August-05-2011 at 12:42pm
Hey all!!!
I have seen quite a few talks about Damper Plates and was wondering what they do, how hard they are to change, and why they even go bad...
A friend here on CCFAN and also someone I know personally on our ski team (phil, 70CC) and us have the same kind of issue going on.
In idle we hear the tap tap click click knock knock coming from below the floor in the back. I've read enough to understand that most likely it is the damper plate. What do we need to do? Is it boat threatening? It is after-all, pretty annoying. Thanks fellas
-Mike
'90 Ski (sold)
'00 Sport
Mississippi River - Bellevue, IA
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 2:44pm
Mike,
The dampner is really a flex coupling to the trans. They have springs between the main plate that attaches to the flywheel and then to the output splined hub to the trans input. The springs fatigue and do break. Back in the days when solid couplings were used, the modern hydraulic marine trans's were being torn up by the torsional vibratins from the engines.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 2:57pm
as far as i know they sometimes do that noise if the idle is set low....
mine does it when I put into gear, give some gas and quits..I have a new damper...
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 2:59pm
You know, the boat started doing this when we put the 1442 on.
Would that make a diff?
'90 Ski (sold)
'00 Sport
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 3:24pm
With the increased surface area did the 1442 drop your in gear idle rpm?
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdvalant Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 3:25pm
It might have...
Phil has a 97 ski with the same motor same tranny we have in our 2000 sport. Both of us had our problems start when we put the 1442 on.
When we move the throttle JUST off idle the tick knock goes away.
'90 Ski (sold)
'00 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 9:28pm
i had a 1981 ski with a bad(really bad) dampner plate and i went thru several transmission front pumps before i found the problem. i never noticed any stange noise from it being bad. i personally made some extreme noise when i would put in a new front pump, go to the lake to ski, and after 5 mins in the water the boat would not go forward . finally noticed the bad plate, replaced it and the front pump..again., and as far as i know the boat is still in operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2011 at 9:40pm
Bill,
It's great you figured out the problem bu It's also sad that you had the tran's problem due to a 100$ plate!!! At least you got it figured out!
