  New Posts New Posts RSS Feed - 1984 2001 rebuild. Pete, go away.
 Post Reply Post Reply Page    <123
MI-nick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MI-nick Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2011 at 12:18am
interested to see the results of the adhesive test...in the name of science...i like the cop boat idea too...old style red and blue bar on top of the tower would really set it off hahaha
As far as I can tell, I'm not quite sure...
bbishop1974 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bbishop1974 Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2011 at 1:42am
Max, i know iam late with my 2 cents,not that it means much.i have no experience with trex in a marine application but i can tell you from experience that it looks like a$$ after time in exterior use.it sags like crazy.i know it will not be exposed to direct sunlight but it wiil be exposed to heat.i dont know if it would be a concearn,but may be worth considering.BTW i like your interior,very retro.loose the bottom paint and your boat would be sweet.whatever you decide,thanks for saving a sweet boat.
Maximal691 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2011 at 4:01am
Thanks bishop, I'm not worried about how it looks, because if I use it, you will never see it. In it's correct application, as a deck, it does hold up very well. Whatever decks you have seen where it sags like crazy and looks like bad, the builder/carpenter/contractor/homeowner either didn't compensate for the extra weight of it or didnt have proper spacing.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2011 at 11:53am
reminds me of years ago when wolmanized started hitting the scene, my uncle spaced the floor with paint sticks between each board and about 2 years later the chair legs would fall thru the gaps
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 4:49pm
Have any of you guys been able to keep the boat on the trailer and just jack the bow? The front portion of my secondaries are lifted about 1 inch off the hull, is this from the hull being on the trailer? Or because they are just crowning while they dry out. If they are crowning while they dry out, it worries me because I'll be using them as my template. I would like to keep the trailer under the boat due to space constraints of my garage and they way I have to have the trailer turned. Also does anyone have any close ups of where they jacked the boat up on the bow and what you used to to cradle the hull.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 4:58pm
I only removed one stringer at a time on my 83 when I did it so your support needs may vary, but I left the trailer under it and supported it only at the transom and the keel in the front.    I just dropped the nose of the trailer and put blocks topped with slightly shaped 2x4s under each side of the transom. Then without removing the trailer I lifted the front of the boat by the lifting eye with a cherry picker and placed another few cinder blocks with a v shaped wood block about 6 inches behind the point where the keel starts to curve up. The whole thing was then sitting only an inch or so above the trailer, I figure the trailer under it should keep you from hitting the floor should your blocking skills not be so good.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 5:13pm
Ok that's about the exact route I was thinking. I'll get her in the air today.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 5:58pm
In related news, an order from us composites was delivered today.
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 7:25pm
So,   Are the Test Results in yet ?
ny_nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 7:35pm
Interested in finding out how your visit with Joe went Max. How do you like the Coosa?
- Jeff
1999 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 9:07pm
Joe is a great guy, super knowledgeable with nice boats to prove it. The coosa is awesome, something I would have no problems knowing it was in my boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2011 at 9:23pm
Also, I aquired a PA system today. It was a ton of fun when I had one in my jeep, I think it will fit in great with the boat.
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2011 at 11:38am
HA this is a police boat!! "PULLOVER, YOU with the tube!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ny_nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2011 at 4:20pm
I was thinking more along the lines of "Ladies, I'm going to have to ask you to remove your tops".
- Jeff
1999 Ski Nautique
Ed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed Quote  Post ReplyReply Direct Link To This Post Posted: December-21-2011 at 5:08am
Max,
Nice looking boat!! Good luck with it, it's gona turn out nice!!!!
WOFTAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WOFTAM Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2011 at 1:04pm
Nice thread. I have a book that I have used in the past for varoius projects that you may be interested in picking up:
Elements of Boat Strength- David Gerr
On another note, this CC is certainly one that did not go with the traditional rebuild. Twin screw ski boat? Take a lookee youself
TWIN SCREW CC
I'll bet the PA works well.
I cant figure out why nobody has picked up this gem. It has been listed for awhile on the craigslist in my area.
Good luck.
Just because you can does not mean you should.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2011 at 1:10pm
Pete - (Twin Screw CC) You will have to update your alignment video to cover that one.
Eric - Do you have a manual for that gear box?
I wonder how easy it is to dock with 2 screws?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2011 at 2:40pm
ya sometimes a home fabrication like that scares people especially for that price. What? Looks like a lot of problems to me. I dont think he'll ever sell that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2011 at 12:16am
Well I did a few quick tests using some US Composites Epoxy. I let it cure for about 4 days.
The Trex has a layer of material about 1/32 thick of uniform brown plastic that wraps over the top around the sides and maybe 3/16 around the bottom. It has the fake wood grain pattern and no doubt some serious UV stabalizers. The majority of the bottom is exposed composite material. I wanted to test both sides. I didnt score or sand any of the materials but I did prep the trex with acetone.
in the first test I epoxied (using a layer of epoxy mat between two materials) two pieces of trex to a hunk of pressure treated 2x6. One piece of trex glued on the top side, one glued on the bottom side. Results are shown below.
Top side fail.. it took little effort to knock off and there is no residual epoxy.
Bottom side - not so bad.. failure occured at the wood material .. no adhesion failure.
Next test is a bedding scenario of a stringer using the side of the trex as it ships, I used a bit of coosa as the substrate for comparison.
This test was a fail for certain, it took no real effort to pull the coosa off and take all the fiberglass material with it
the next sample uses an end of the trex with a cut from a table saw..
It took more pressure to break it apart but it still failed at the joint although it pulled a glass out of the joint with it
An improvement but the saw cut seemed smoother and perhaps the heat of cutting effected the material locally because the cut edge clearly did not hold epoxy as well as the bottom.
I did another sample with coosa attached to the bottom surface
And it took a lot of force to break it but it failed the coosa --both sides of the joint held.
My humble opinion - you could use it if you cut off the wood grained coating... and even then I would sand the substrate material because I wouldnt trust the saw cut surface. The bottom face sticks plenty well, but the coating is a bit of a spoiler I dont know if it woudl work to sand it but I wouldnt trust any bond made to it.
I think it would take a lot of work to make it work well as a stringer.
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2011 at 12:34am
Joe,
A big thanks for the tests, I appreciate the effort and help. I guess I'll go with wood for the secondaries and trex or azek for the rib supports.
MIskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MIskier Quote  Post ReplyReply Direct Link To This Post Posted: December-24-2011 at 2:33am
TWIN SCREW CC
Good luck.
That boat has been for sale since early June!
2006 MasterCraft PS 190
1986 CC Ski Nautique 2001
YooperSully View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote YooperSully Quote  Post ReplyReply Direct Link To This Post Posted: December-29-2011 at 7:14pm
Two Questions have come to me during reading this post. First has anyone considered the Expansion/Contraction properties of Trex. If you do your fiberglass work in warm weather like most fiberglass needs, then you store in the winter( Gets to 20 below F. here not sure where everyone else is) you might be encountering a 90 degree temperature change. A few years ago a product came out for residential exterior trim called Azek. Now I now its different then Trex but I would imagine not by much. When I first came across it I researched the installation instructions on line and followed them to a T. The company was our of Pennsylvania so I figured that the seasons were comparable to ours. Two fasteners were required every 16" for 1x4 trim and pieces joining each other were glued with plumbers pvc glue. In our neck of the woods this stuff would bow and warp terribly in the summer and then in the winter it would shrink and gap. On a few places I noticed it even sheared the fasteners (16gauge). I vowed not to use it anymore. Then last year I had a customer who required it in there project so I called the company to voice my concerns and to see what they would recommend. They had stated that they had changed their fastening schedule to accommodate the expansion/contraction that I had experienced. They now recommend that you use two fasteners every 8" and fasteners no smaller than a #8 trim screw. All in all I guess the point I'm trying to make is that these (poly) composites move quite a bit and with out heavy duty fasteners locking them into or onto a substrate they will definitely move with the change in temperature.
My second question was about the trex that is pictured. The Trex we get in the Norther Mid-West is wood grain both sides and uniform color throughout. Not like the piece pictured. I was just curious if what your using is real Trex or if It's a big box stores Version.
IMO I'd never use a product that can be bent into a arch on some ones deck as something that is suppose to be straight in my boat.
87' 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: December-29-2011 at 11:58pm
Yoopersully, I did go over the thermal expansion on one of the previous pages. I ended up using pine for the secondaries, I glassed them in the other night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maximal691 Quote  Post ReplyReply Direct Link To This Post Posted: January-27-2012 at 9:04pm
Does anyone have measurements of the battery box to the pylon?
