1982 2001 model |
Dellavalle
Newbie Joined: May-26-2012 Location: Lake Placid Status: Offline Points: 16 |
Posted: May-26-2012 at 10:30pm |
First use of the year, started at home, take to the Lake, no go. Just cranks, drained fuel, water filter, good gas, no ignition / firing. Any idea's ? Thanks for the possible solutions.
76tique
Senior Member Joined: April-12-2009 Location: Nyack, NY Status: Offline Points: 226 |
Do you have conventional ignition? Condensers often go bad from sitting...check your points/condenser if no spark. Do you have power to the coil with ignition on?
Dellavalle
Thanks for your suggestions, It did start and run in my driveway at home, drove 1 mile to the lake, and no firing. Original ignition system, and I will check for voltage at points tomorrow a.m, plus rotor, and cap. After I drained out the fuel / water filter, there was some water in the system. So, fuel to carb. / check power, and maybe t'morrow will be the trick.
SNobsessed
Try dribbling some fresh gas into the carb,then try to start. Just to make sure all the bad gas was purged.
I was helping a friend of mine try to start PWC, drained gas, etc - still wouldn't start. The problem ended up being all the green ethanol goo in the bottom of the tank. He had to have the tank removed & throughly cleaned. The tank is not easily accessed in a PWC! |
Dellavalle
Hello and thanks. I took 2 cans of carb. cleaner, shot everything and more, cleaned up the remains, let it all dry, fired it up and all good. Now, onto the impeller, it was not sucking water in and up, so we had to shut down at the dock. Back home, took it all apart, back together in the right flow of things, but I am installing a hose feed " T " connection tomorrow at the water feed and into the filter. Driving to the lake, about 1 mile, Lake Placid, and not being able to go, stinks. So this way I can run and test at home. Thanks again, P.D.
