Sterling Clamp Mount |
Jones
Senior Member Joined: September-07-2010 Location: Boise Status: Offline Points: 249 |
Posted: August-13-2012 at 9:35pm |
I replaced my steering cable and neglected to make note of where the sterling clamp was mounted to the steering support tube near the stern. I pretty much just centered it and made sure I had an equal range from left to center to right on the wheel. I'm not sure if it would matter but since I replaced it, I have a negative pull on the rudder when tracking. Before, could swear I had a little resistance on the wheel but it could just be the bad cable. I'm assuming it would not make a difference but would appreciate confirmation. If it's not, how do I get a little resistance on the wheel without a tunable rudder? Angle grinder?
1979 Ski Nautique (sold)
1997 Ski Nautique 1998 Super Sport Nautique |
Brad,
It sounds like you set up the cable adjustment correctly. With a non tune able rudder, the vertical edge is ground to put a load on the rudder in one direction. |
Jones
Thanks Pete. Probably a dumb question but that would be the leading edge?
Jones
I did a search and it appears to be the trailing edge. I'll give it a shot and see if that helps.
WakeSlayer
Trailing edge for sure. You should be able see where it was ground originally.
Mike N
1968 Mustang |
