  New Posts New Posts RSS Feed - Need Rear Mounts PCM 1:1
echo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote echo Quote  Post ReplyReply Direct Link To This Post Topic: Need Rear Mounts PCM 1:1
    Posted: August-28-2012 at 12:22pm
Mine are frozen. Need a new set pcm 1:1 transmission.
dwcar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dwcar Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2012 at 3:15pm
83Ski
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-28-2012 at 4:19pm
try dipping them in a mix of atf fluid and acetone, let it sit for a while and work it out in a bench vise...
if they collapse then you could say at least you tried to save them...lol
<a href="">1992 ski nautique
ArtCozier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ArtCozier Quote  Post ReplyReply Direct Link To This Post Posted: January-08-2013 at 11:35pm
I'm pretty sure that I have a pair, but I'll need the part number that's cast into the stringer bracket. It will start with R090......
"Art"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 9:41am
Jim,
Many do find them locked up but as mentioned they can be freed up. I suggest removing them as well then get the rubber off and then go after the split clamp area with penetrating oil. The 50/50 mix of ATF and acetone is proven to be fantastic. Then the next best is Kroil.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 11:12am
If you don't get them freed up give me a call! Also Echo what year is the boat as there were some differences on the 1:1 boats. 1998 changed but there were very few 1:1 boats made in those years.
