oil pressure gage |
mrfreeze001001
Newbie Joined: December-25-2012 Location: ohio Status: Offline Points: 20 |
Posted: March-13-2013 at 7:29pm |
when i turn the key on the oil pressure gage goes all the way up any info would be helpful its a 94 ski nautique 351 engine.
Disconnect the wire at the oil pressure sender,don't let it touch anything and turn on the key. Report back with what happens.
mrfreeze001001
disconnected wire at oil sender still gage is peged all the way up. checked voltage on wire unhooked 9 volts hooked up 7 volts. Just got boat in dec. the sticker on it was 2006. and it has been sitting out side the whole time uncovered. hade to rebuild the whole trailer. found out the engine is not the original one m# and ser.# show engine is from a 1978. had to rewire the whole dash everything green from setting outside. got engine started last weekend and found oil gage problem. first cc so any help is apreceated. hope i didnt over pay for it. 1994 ski nautique. 350 hours is what gage shows payed 1,500
Bri892001
My guess is that the problem might be on the dash side.
You could have accidentally connected the "S" Sender terminal directly to a ground. I found the stock gauges on my 93 to be a little odd. Pete was saying a while back that the gauge itself shouldn't have a ground, except for the ground for the back light. Because, the sender wire is essentially a ground wire, and the sender is a variable resister to ground (in this case the engine). Anyway, my temp gauge, seemed to have a ground terminal for the light, a sender terminal and also a ground terminal. If your oil gauge is the same way, you could have mixed them up (it would be easy to do). Long story short, a Sender terminal connected directly to a ground, would give you this pegging effect you are getting. |
I would now try it again after removing the sender wire from the back of the gauge,if it's still pegs the gauge is bad. If it's down you have a bad wire you'll have to trace out
I agree to the above and to take a look under the dash.
turningpoint84
Platinum Member Joined: September-11-2008 Location: Cincinnati, OH Status: Offline Points: 1467 |
$1,500 for a 1994 ski nautique? Over paid? LOL.
Proud 1968 mustang owner and now
1970 Mustang |
gR@HaM
Platinum Member Joined: May-01-2012 Location: UK Status: Offline Points: 1265 |
Was thinking the same!! |
'82 Ski Tique
mrfreeze001001
thx for the info. found the problem. at the engine wireing plug.i think im going to get rid of the plug and just wire all the wires direct with out plug. just can't believe this is so bad.they have butchered everything they tryed to fix. no wonder they give up and left for dead outside.
Bri892001
If the harness plugs are a mess that might be your best option.
Also, You can buy a brand new engine wiring harness if you think that's in order: http://www.skidim.com/prodinfo.asp?number=R121025A |
mrfreeze001001
i just got rid of the plugs thx
