Octane./ ethanol treatment |
Guests
Guest |
Posted: April-20-2013 at 11:28am |
Question. The book says 89 octane.
What are you guys going with? Is 87 ok? __________________________________________________________________________ ethanol treatment? Is Valve tech any good? Sta-bil................I think that is what I use, any good? Like x amount of Oz per gallons of fuel.. |
GlassSeeker
Grand Poobah Joined: November-26-2008 Location: Elk Grove, CA. Status: Offline Points: 2421 |
I would not run a lower octane than recommended.
I burn my gas fast so no treatment. |
This is the life
skutsch
Grand Poobah Joined: June-19-2008 Location: Racine, WI Status: Offline Points: 2874 |
I drive 50 miles roundtrip to buy gasoline with no ethanol, so that is only 91 octane. I do use stabil, if I end up with some ethanol blended fuel, then I use the blue stabil (marine), it also goes in my snowmobiles, if they happen to get any ethanol blended fuel. In general though I avoid the ethanol blend like the plague...
Foot_Fungus
Gold Member Joined: February-27-2012 Location: Chapin, SC Status: Offline Points: 501 |
89 at a minimum. I'm lucky enough to have an ethanol free gas station right down the road. I run mid grade in the early months and then premium once the temp breaks 80(I run at barefoot speeds 90% of the time so I want to ward off any pinging with the heat, otherwise no benefit from higher than recommended octanes). Blue Stabil is what I'd rec., but like glass pointed out, unless you let gas sit in the tank you prob don't need an additive. From what I've been told enthanol blends do most of their damage when they're allowed to sit.
'94SN Restoration underway...
Guests
Guest |
ok ty ... 89 it will be, I was reading in the book that if you run lower to set timing or retard the timing to -4
