  New Posts New Posts RSS Feed - Steering
Steering
Shannon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shannon Quote  Post ReplyReply Direct Link To This Post Topic: Steering
    Posted: May-10-2013 at 7:53pm
Can anyone tell me if there is a way to ajust the steering in a correct craft to make it eaiser to turn the steering wheel. Mine feels like it has a bad drag to it. Takes two hands to turn it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 8:41pm
It would help alot if you stated the year and model,if the cable has ever been changed,if you disconnected the cable from the helm and rudder to check and see if in fact the helm,cable or rudder or all the above is at fault
Most likely you have an older boat and the cable needs to be replaced,but you need to check first.
GlassSeeker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlassSeeker Quote  Post ReplyReply Direct Link To This Post Posted: May-10-2013 at 9:59pm
I'm betting worn out cable. Replace and rejoice
This is the life
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-11-2013 at 7:45am
+1 on the cable. Follow Gary's procedure to check what's binding.
