  New Posts New Posts RSS Feed - High Heat Paint or Engine Enamel?
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Topic: High Heat Paint or Engine Enamel?
    Posted: November-20-2014 at 12:32am
My exhaust manifolds and risers just came out of a hot tank. Now I'm looking to paint them before re-installing.
I'm trying to determine if I should go with the Rust-Oleum High Heat paint (2,000 degrees) or the Engine Enamel (500 degrees).
Obviously in an automotive application, I would go with the High Heat paint. But I don't know how hot the water-cooled exhaust manifolds and risers get. Do the water-cooled exhaust manifolds and risers get hotter than 500 degrees F? If so, then I will use the High Heat paint, if not, then I will go with the Engine Enamel.
I'm also thinking about going with black on the exhaust manifolds and red on the risers. The engine will have a nice red/black color scheme going with the red valve covers, red HEI distributor and red risers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 12:59am
Rob,
Engine enamel and keep the colors original. When are you going to post a picture(s) of the boat?
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: November-20-2014 at 8:50am
Don't bother painting the runners that attach to the head, they will just burn off & create smoke. If you 2 tone, do the embossed PCM text. Maybe just a racing stripe on the risers would look good too. JMO, sorry Pete!
