WATER STRAINER- bracket? |
SWANY
Senior Member Joined: August-12-2014 Location: batavia Status: Offline Points: 384 |
Posted: January-18-2015 at 1:58pm |
I keep looking at the stress on the hose by the trans cooler from the unsupported weight of the water strainer and hoses. I will be replacing all those hoses in the spring, but I'm thinking of making a bracket to support the strainer. From the strainer inlet side down to the trans mount bolt. Has anyone else done this? pictures? or is there a factory bracket?
thanks for input |
SWANY
Joel, I may be wrong but I think you would be the first with the bracket. I have never seen one from the factory but again, I may be wrong. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21116 |
Your perceived issue is due to the lack of wire reinforced hose on your boat... Get some of the proper hose on there and the weight of the strainer won't be a concern. I've seen some strainers zip tied in place but never seen that style with a bracket.
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
My 87 with a 351 has a bracket, but the strainer is down on the side of the engine, not hanging out up over the back of the engine like yours.
1987 Ski Nautique |
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13511 |
Nothing wrong with anything in the picture, including the hose type. Make a bracket if you wish or move to wire reinforced hose but neither is factory or necessary.
SWANY
Just double checked and the hose has some sort of reinforcement in it, because I can see it on the end. Granted all this hose could be original and "breaking down" rusting inside. I'm really on the fence if nobody else has had issues. I have ordered 12' of 1" ID wire reinforced hose already for all the hose replacement.
Looks like heater hose, probably fabric reinforced- definitely not wire reinforced, and not original unless my memory is completely failing.
I'd like to see the bracket on your 87, Dave... I've only seen the short lived early 80's style pool strainers with brackets. |
Hollywood
I have never seen an original 80s PCM with wire reinforced pre trans cooler.
marlo14
Groupie Joined: February-08-2014 Location: Illinois Status: Offline Points: 46 |
They do make a bracket. I don't know how/where you would mount it, or if it's necessary considering how many boats have the hose as the support. It is basically a piece of flat steel bent in a "u" shape and a hole in each "ear" of the u. The strainer fits up in the "u" and then the inlet and outlet nipples go thru the ears and thread into the strainer, acting as the "bolts" holding the strainer to the bracket. I wouldn't bother with it.
On a side note, I ordered some replacement hose from one of the "big box" watersports catalogs. I made my order over the phone on a Sunday, which is handled by a call service and not actual company people. When i received the order, it was correct, but they shipped my hose in 15 one foot sections! They did make it right when I called during the week. |
Brandon, Is their specialty tubes? You probably would have been better off going to an industrial supply like McMaster Carr. At least they corrected the problem. |
marlo14
Yes, the catalog is about half tubes now! That was about 15 years ago, and it was probably a new order picker and not the answering service like they put the blame on. Made me laugh until I started wondering if their solution was going to be 14 hose barbs with clamps!
Hollywood
SWANY, in 88 PCM changed the hose routing a bit. I don't know if they really intended to take the torque off the cooler but it definitely does that. The real benefit was probably just less length needed.
The hose curves straight up then into a 90, and a 90 out and down directly into the strainer. The original design has the strainer hanging but I'll bet there's clearance for the doghouse with it upside down, which would definitely make removal easier (and self draining). I would keep the original routing and just replace with wire reinforced, possibly with some sort of support bracket/tether to make yourself feel better but it's definitely not needed. Tim, looks like 89+ PCM started using wire reinforced all the way back there. |
quinner
Joel, fwiw, my 05' is factory routed pretty much like yours, all lines are wire reinforced, no bracket.
SWANY
Thanks guys. Maybe I'll make something like the bracket thats used to hold the blower hose....
OverMyHead
Well , I crawled under the covers and saw whats there. I could only lift the dog house about a foot with the cover still on so I did not have enough hands to take a photo. My cooling routes from the hull intake, just over the port rear engine/tyranny mount, to the water strainer, under the engine to the tyranny cooler, then up to the fresh water pump. The "bracket" is an "L" bracket and a big hose clamp bolted to the engine cradle. Definitely not factory. |
1987 Ski Nautique |
Hollywood
This doesn't make any sense. |
OverMyHead
My transmission cooler sits under the front of engine up near to the bilge drain. Never questioned it till now.
1987 Ski Nautique |
Hollywood
Interesting. The transmission is in the square end, but the cooler is in the pointy end.
OverMyHead
Yes, a very direct cooling water path, but longer lines from the cooler to the transmission I suppose. It has always worked, should I have concerns?
1987 Ski Nautique |
Hollywood
No. Many other inboard mfgs snug the cooler up on the front of the engine, even post raw water pump. Adds a cleaning step when you frag an impeller.
SWANY
One way to go would be to replace the hoses with the new wire reinforced that I got from Zach and see how much it firms it up. Although shouldn't there be anti freeze in those lines from winterizing?
Joel,
You don't need anti freeze in the hoses as well as the trans cooler. If you did get some back there, it will be between the RWP and the high side of the hose next to the strainer. Just pull them and install the wired hose. Trust me, the new hose will firm it up plenty. The stuff is even hard to bend in tight areas. |
SWANY
I Replaced the hoses, it definitely made that set up stiffer, enough to not bothering wasting my time making some fugly bracket I guess. Would any of the "upper" hoses have coolant in them, that I could replace now?
Joel, As mentioned, don't worry about having any antifreeze in the hoses. You've got it in the block and it will stay in the low spots which is the key. If you remove hoses and find frozen antifreeze in them, don't worry. Keep in mind that the RV temp rating is burst protection and not the freezing point. |
