Impeller shredded into the cooling system |
Author | ||
BillG
Newbie Joined: August-25-2015 Location: Altnata Status: Offline Points: 3 |
Posted: August-25-2015 at 9:15am |
Boat overheated 8-23-15, So I checked the impeller and removed the remains of a shredded impeller; and don't know if the rubber pieces will flush through the cooling system, or if they could get stuck somewhere. Help please, can't afford an expensive repair.
Bill
JoeinNY
I am more of a watch for problems type than a go look for problems type, check the hoses immediately up and down stream, if you don't find nothing then keep your eye on the temp gage and exhaust manifolds. If you have no overheating issues, and your manifolds are cooling evenly after a month or so they probably passed cleanly.
Impeller parts will get stuck in the thermostat housing and possibly between the cooler and the pump.
Morfoot
Save all the pieces that you pull out and you can kindasorta recreate the impeller. By doing so you know if you have most if not all the parts of whats left of it and you'll know if you need to 'Go fish' some more.
kytom2
Gold Member Joined: July-25-2007 Location: Maysville Ky Status: Offline Points: 698 |
"Save all the pieces that you pull out and you can kindasorta recreate the impeller"......
You really need to find a hobby Tim, way to much time on your hands. |
geecee
Senior Member Joined: September-06-2013 Location: South Africa Status: Offline Points: 206 |
I found a lot of pieces at the oil cooler
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13513 |
Depends on the marinization. My trans oil cooler is up stream of the RWP.
baitkiller
For some crazy reason I have found it quite common for impeller pieces to travel both up and down current. I have no idea why. This is all marine inboards, not just ski boats. I typically open the hose connections at the end-of-run both sides of the pump and start blasting with a water hose. The only troublesome condition is small bits in the T stat. Vanes will also lodge in the pump cam and if not removed will wreck a new impeller. |
I totally agree and even tried to convince Kevin a couple weeks back after he criticized my check the trans cooler comment! When you pull the boat out of the water, the broken pieces back flush along with the water draining. |
Bill, Have you been running the engine even briefly without water? The RWP is water lubricated. |
