  New Posts New Posts RSS Feed - 3/4 hose from water pump to exhaust manifold
KooK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KooK Quote  Post ReplyReply Direct Link To This Post Topic: 3/4 hose from water pump to exhaust manifold
    Posted: August-03-2016 at 5:38pm
1979 Mustang 17 302 4v w/ Commander exhaust manifolds.
So just a real quick question. There are 4 hoses, all 3/4 inch ID on my exhaust manifolds and they're getting a little old and need to be replaced. Where I'm at there is no boat specific parts store so I'm limited to the auto parts store or online ordering. Does this 3/4 inch hose need to be high temp and high pressure? Does it actually carry much pressure (can I use heater core hose?)? What came off it was a Goodyear Horizon 200 hose and I can't find that anywhere near me. Just looking for some suggestions on what to put back on.
Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2016 at 5:44pm
Aaron,
You're good to go at the auto supply. Just normal heater hose works. The pressure is minimal and typically only about 4 PSI
Irydslow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Irydslow Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2016 at 2:24pm
I used high-temp hose from the hardware store...worked fine so far! Just moving hot water from point A to point B.
78 Correct Craft Southwind 20
