  New Posts New Posts RSS Feed - Fuel Fill Ground Wire
trice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trice Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Fill Ground Wire
    Posted: March-28-2017 at 11:25pm
The original fuel fill in my 87SN was removed and replaced with a black plastic one of larger diameter. I'm installing a new SS fill similar to the original. Question: I have a lone 14 or 16 gauge black wire that looks to be a dedicated ground wire for the fuel fill. I haven't traced it, but the wire runs toward the front of the boat with the sending unit wires and anchor light wires. Is this the ground wire for the fill? Do fills need to be grounded and to where? I have the dash wire diagram, thanks CCF! Anybody know where I can get a diagram of the rest of this boat's electrical system? Thx.
87 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2017 at 11:31pm
Thomas,
Yes, you need a ground at the sender. It's the ground source for the gauge. The gauge itself has the + feed. Ohm out or trace the wire you found to make sure it goes to the engine block
Post Options Post Options   Thanks (0) Thanks(0)   Quote trice Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2017 at 11:58pm
Peter,
I believe my sending unit is already properly grounded. Unfortunately i don't have any gas in it to tell if it's working properly. I have powered the system with battery and the fuel gauge moves to the empty indication. What about grounding the SS deck fuel fill? Did the original rear wiring include a ground wire that was connected to the deck fill? Thx.
87 SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2017 at 12:09am
Yes the filler needs to be grounded to eliminate static electricity.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2017 at 6:27am
Thomas,
Sorry, I sure misread the question. It was a long day for me. Gary is correct.
Duane in Indy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Duane in Indy Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2017 at 7:43am
A good habit to get into is grounding the fuel nozzle to the filler neck BEFORE unscrewing the filler neck cap. Any static discharge is done with the fuel fill still closed.
This is important enough that aircraft require a retractable static cable attached to the fill station and then an alligator clamp to afix to the airplane before refueling. Then ground nozzle using procedure above
        1978 Mustang (modified)
