  New Posts New Posts RSS Feed - Prestolite Clip Down -
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Topic: Prestolite Clip Down -
    Posted: July-08-2006 at 9:31am
Anyone else have a problem with the black versus brown cap.
My new cap from DIM is black and simply doesnt snug up enough to run.
I remember someone else going through this (or some other black versus brown issue) a few years ago on this site.
All comments appreciated.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2006 at 9:36am
I have a new black one on the bench, havn't tried it yet.
hmmmm. Black n' Tan, that reminds me..
I can't try it till mon or tue.
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: July-08-2006 at 9:53am
In my frustration yesterday I went to the local Napa to review the Parts book.
In the pleasurecraft section they list two clip down caps. Part number 18-5369 (black)and 18-5389(tan) Sierra replacement Numbers. Rotor 18-5407
Similarly, In another Napa book there is two Clip Caps listed for use with the AL125 rotor -
An AL124 and An AL125 cant tell the colors.
Please let me know how your new one fits. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2006 at 3:42pm
Hi Stang
Don't know what you mean by "doesn't snug up enough to run"
Do you have the rubber gasket between the distributor housing and the cap in place?
If that's not there things could be sloppy.
I've used both brown and black from various companies over the years with no problems.
keno
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2006 at 8:48pm
yes i used the gasket. doesnt snug up means loose, moveable to the extent the boat wont fire.
i can switch caps back and forth all day. old cap stays tight and boat runs great. new cap just will not get tight.
advsouthwind View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote advsouthwind Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2006 at 11:46pm
you have to bend the tabs on the distributor clips until it is snug. you may also find a poor fit on the rotor.{a little loose},thats what i ran into there again you have to bend the tab out a little . remember use a needle nose to supportthe spring clip while bending with another pliers. do it in small doses and screw down the clip before bending. it makes it easier
gave up sea ray life for a 77 southwind 20 project just livin the dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2006 at 9:27am
thanks everyone,
yes, i did bend the tabs down to snug up the black cap the other day (prior to my post). when i did i must have also knocked it out off square because after i got it on there tight i hit the ignition. boat fired and ran for a few seconds and stopped - the rotor was hitting post on one side of the cap and broke the rotor. thats when i gave up on the black one.
i've subsequently been told that i wont have to adjust the tabs on a new tan one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2006 at 6:31am
Put the fresh black pleasurecraft cap from skidim on my '82 yesterday, no fit problems. I've run tan caps before too, but I think the black fits better on mine.
There must be something to it.
River Rat to Mole
83SN2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 83SN2001 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2006 at 9:50pm
SKIDIM had a bad batch of caps couple months ago. Had one myself. Vince took care of it no problem.
