  New Posts New Posts RSS Feed - hard steering
hard steering
callaway View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote callaway Quote  Post ReplyReply Direct Link To This Post Topic: hard steering
    Posted: July-09-2006 at 10:10am
Hello,
I have a 1989 SN 2001. The steering has become very difficult. I am not sure if this needs a steering cable replacement or if there is some other issue. If anyone has any suggestions I would appreciate some advice. I am also not sure if there is any place to lubricate or grease.
Thank you,
Don
trikeaholic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trikeaholic Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2006 at 10:41am
mine was pretty stiff also, all I did was turn the wheel all the way each way and lube both ends of the cable with grease a few times. It wasnt long until the steering was smooth as butter.
1980 Ski Nautique
Ithaca NY
My Boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2006 at 11:53am
Its probably the cable, but do a quick test first: disconnect the cable from the rudder (at the rudder) and see how the steering feels. If its smooth, then drop the rudder and smooth up and grease the shaft. Most likely though, it will still be hard to turn, indicating the cable is the cause of your problems. Try Trike's solution. If it doesnt help after a while, replace the cable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote callaway Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2006 at 6:06pm
Thank you trikeaholic and TRBenji for your advice. I will give your suggestions a try.
If it is the cable and suggestions where to buy?
Regards,
Don
Rochester, NY
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2006 at 1:10am
Call Woodie at Southeast Correct Craft.
BrentAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrentAL Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 4:04pm
trikeaholic what kind of greese did you use?
Brent
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 4:20pm
skidim.com
Mullet Free since 93
95 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrentAL Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 5:12pm
I dont see anything there.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 5:20pm
Steering Rule #1- don't let your boat sit all winter without working the steering back and fourth at least every two months.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 8:24pm
http://skidim.com/prodinfo.asp?number=TELSSC6116
not sure what length you'll need.
95 Sport
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2007 at 6:40pm
Dudes,
my sport has been difficult to steer at times. After skiing through december and into New Year's I decided to do some work in January. My buddies MC is on a lift in the water so if I get a few chances here in January, it'll have to be behind his boat.
I just disconnected the steering cable and wallah! Wheel turns easy as pie. So then I thought the rudder would be a tough turn, but when I got under the boat and turned it, it turned easy as pie too. I guess I'll grease the cable and drop the rudder and grease it too. Any other things I should try?
95 Sport
k9spd403 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote k9spd403 Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2009 at 5:50pm
any one have a vendor they use for the cables mine is only hanging up and becoming hard to turn when i turn the left.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2009 at 5:55pm
All newer CC's (starting with the 2001 hull in 1982) use special Correct Craft steering cables that can only be ordered through the dealer. Trying to retrofit a generic cable will result in headaches and a decreased turning radius once youre done. White Lake Marine has good pricing.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: March-31-2009 at 2:27pm
Also try looking at the helm tilt mechanism.. mine had a bump in the steer when going side to side.. It didnīt show out of the water but it was hard while floating navigating on any speed. Solution was to adjust the inside assy (you have to move the rubber boot that covers it)... no need to replace the cable.. now it steers smoothly...
Hope you get my explanation
<a href="">1992 ski nautique
