How Much Engine Oil? |
Fiberglassic ![]() Groupie ![]() ![]() Joined: October-09-2017 Location: Raleigh, NC Status: Offline Points: 62 |
![]() ![]() ![]() ![]() ![]() Posted: April-16-2019 at 5:04pm |
Can you experts please help me with the correct amount of oil I should get out of this Chryslers crank case pan? The Correct Craft is a 1965 Barracuda and the engine was an entire swap out in the early 90’s. Below is everything else I know.
• Very low hour, perfectly running 1990, maybe 80’s L 318 Mopar • On trailer, 3rd wheel full up, hull water flows very slightly toward bow. • Dip stick mounted port rear bottom of crank case reads right at Full line. • Cold, from inside oil tube sucked a hair more than 5 qts oil out, now dry. • Very Large PH8A (I know) held at least a ½ qt of oil. • Has no front or rear oil drain plug, only other is starboard rear bottom of pan. Question is do I still have oil in the front dip of the pan and if so how can I get it out or do I have to add 5 fresh qts of oil to it. Thanks…Scott |
Scott
