  New Posts New Posts RSS Feed - Holes don’t line up on new flywheel
Dugedog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dugedog Quote  Post ReplyReply Direct Link To This Post Topic: Holes don’t line up on new flywheel
    Posted: July-25-2019 at 10:04pm
Maybe I’m nuts but the holes on the new flywheel don’t quite line up with the holes on the old one on this 83 Nautique.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2019 at 10:13pm
Did you follow Ken's suggestion from the other thread?
You tell the guy at the parts store that you need a flywheel and/or ring gear to fit a 1967 Mustang with a 289 and a 4 speed transmission.
The ring gear is 157 teeth.
Don't tell them you need a flywheel for an automotive 351w because those all had 164 teeth and were a bigger diameter .
Here's a picture with the Ford part number cast into the flywheel There have been a few updated part numbers over the years but they're 157 teeth in the marine application
BTW, keeping every same topic in the same thread makes it easier to follow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2019 at 10:39pm
Which holes are you talking about? The 6 center holes where it bolts to the crankshaft or the holes where the damper plate would bolt on?
The 6 holes in the center aren't evenly spaced at every 60 degrees, it only goes on one way so that the counterweight is in the right spot and the engines balance is correct
Instead of every 60 degrees it goes 60 60 60 60 56 64 . It's hard to see by eye. It's Ford's way of making it only go on one way
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dugedog Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2019 at 10:34am
Ok, got the holes to line up. Thank you for that. If I could just find some torque specs. The chart I have is not real clear. I need damper to flywheel, and shaft coupler mainly. I really appreciate y all’s help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2019 at 6:07pm
For the damper to flywheel somebody might tell you to look up the torque specs for a 5/16-18 coarse threaded bolt but it varies with bolt grade so you'd need to know that bit of info.
I've always done 20 to 22 ft lbs and haven't had one fall off yet
For the coupling they are 3/8 24 fine thread stainless steel bolts but a torque chart will vary depending on type of stainless steel so it's kinda a crap shoot.
30 ish works for me.
