  New Posts New Posts RSS Feed - Stiff steering
Stiff steering
schultz227 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote schultz227 Quote  Post ReplyReply Direct Link To This Post Topic: Stiff steering
    Posted: August-25-2019 at 8:49pm
92 SNOB 351 ... with stiff steering to the right , replaced the cable no help , I thought long ago on here I saw some talk about filing or sanding the rudder on one side to solve the problem ? Could be way off base here but any help would be much appreciated . Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2019 at 9:24pm
Stiff or actually “pulling”, like if you let go it immediately turns?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2019 at 9:29pm
Kyle,
Pulling toward starboard is due to prop torque. Some actually like the pull rather than a neutral rudder since the pull keeps you running down the course straight and not in a zig zag. Here's a thread on rudder tuning if you want to give it a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote schultz227 Quote  Post ReplyReply Direct Link To This Post Posted: August-25-2019 at 11:12pm
It’s stiff when you try to turn to the right , takes both hands ... it tracks fine
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2019 at 3:37am
I had stiffness that drove me nuts that was kind of intermittent and it turned out the rudder packing was dried out once it was replaced, it was resolved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: August-26-2019 at 6:02am
Kyle,
As Peter mentioned, check the port by disconnecting the cable at the tiller arm. If the port isn't bound up then you'll need to move forward and check the helm.
