  New Posts New Posts RSS Feed - Trailer Brakes, Never Dealt with these *Pics*
C_Heath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Topic: Trailer Brakes, Never Dealt with these *Pics*
    Posted: March-12-2020 at 3:27pm
This was talked about in an earlier thread but I wanted to start a dedicated one to reduce clutter. My first boat since my pro-star 190 20 years ago. Has the new electric box on the tongue. The trailer has DISK brakes and is a Magic Tilt. I mentioned to you guys that I didn't feel any braking of the trailer on the way home from the test drive. I still dont but I did try to back the boat up in the yard last night without the hooks engaged in the actuator and the brakes did lock up so I know that part works but I am not sure about the electric actuator that supposed to apply the brakes when I am actually braking on the road. I've got a 2007 Tacoma Double-cab 4x4 and I need all the help I can get to stop this 2000 pro Air.
Thanks again, here is a pic of the actuator.
1979 Calipso Runabout (the boat that got it all started)
1988 Mastercraft ProStar 190 (sold)
2000 Pro Air Nautique/GT40
zwoobah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote zwoobah Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 4:16pm
Do you have a trailer brake controller in the Tacoma? If not, you need one. The wiring should already be there for it.
1968 Mustang 16 - 351W powered
Post Options Post Options   Thanks (1) Thanks(1)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 4:34pm
As a stop gap back up method (prior to wiring in the controller) I have seen the safety chain hooks hooked onto the fingers (hooks) that prevent the trailer from backing up.
Dreaming View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dreaming Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 4:44pm
Maybe I am missing something here, but this looks like a standard hydraulic brake set up to me.   when the trailer pushes against the truck, (braking or backing) the tongue moves to actuate the hydraulic actuator.   Disk brakes may just feel very smooth in comparison to what you are used to seeing. I am not sure how to test this, but a local trailer shop should be able to help you determine if the brakes are working or not.   As a side note,   I think the wires exiting the trailer through the hole in the steel looks like a place that will chafe over time. I would probably put a rubber grommet in the hole to keep the wire from chaffing, or maybe fill the hole with silicone?
desertskier View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 4:57pm
Looks like a surge brake actuator to me. Have you tried installing just the hitch and try moving it up and down? I just checked the one on the '99 we bought. I jacked up one side then spun the wheel and moved the actuator by pushing down on the hitch.   The brake should engage as the hitch is pushed down.
edit: not sure if yours needs to be pushed down or pulled up but you get the idea.
Post Options Post Options   Thanks (1) Thanks(1)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 4:58pm
plus 1
GottaSki View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 5:27pm
yeah those are hydro brakes
the trailer will just feel 'lighter'
You shouldn't every feel them slow you down, as soon as they try they shut themselves off
Dollars to donuts those wires are chaffed through on the tongue though
River Rat to Mole
SNobsessed View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 5:42pm
An easy test would be to do a hard stop & then check temperature of rotors. Tough guys use their hands, I myself would use an IR thermometer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 6:02pm
going to check All these tonight. Ill report back. Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rebel skier Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 6:35pm
etailer.com sells it and has videos on its installation and how it works. They do not have a manual to download which surprises me.
Just google "titan hydraulic brake actuator etailer"
Faceplant View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: March-12-2020 at 11:23pm
A little bit off the main subject but you really want to cross the chains for safety.
quinner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 10:34am
And your brake safety chain should be connected to the truck not the safety chain
Post Options Post Options   Thanks (1) Thanks(1)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 11:17am
I have the same set up and it is not electric. It is hydraulic.
1968 Ski Nautique, Project.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 11:57am
Correct., The safety chains come to play if the trailer does get disconnected. The reason for crossing the chains is to allow the trailer even side to side movement. If the chains are not crossed, then the trailer will be pulled unevenly on one or the other side. Plus, all the load may be on one chain only.
rosconole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rosconole Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 2:34pm
I would be the reverse lockout is not connected right or getting good signal , it has nothing to do with controller in the truck for electric brake , it does how use blue wire lead I believe in the wiring harness. check white ground as well on trailer.
1989 ski nautique ,1991 barefoot nautique, 1993 Mustang Cobra 1998 5.0 Magazine shootout invitee
Post Options Post Options   Thanks (1) Thanks(1)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 3:26pm
That is a Titan Hydraulic actuator for sure, a Surge Brake. Not Electric.
As mentioned some do add a reverse lockout that is electric but it is not standard with that hitch. Full electric brakes are not used on boats since boat trailers are submerged with every launch and electric brakes don't like to be submerged in water.
I have the same Titan installed on my car trailer, I put it on about 10 years ago. It works very well.
I will attach pictures so you can see how I set up my reverse lockout. I drilled a hole that blocks the slide from applying the brakes. An electric lockout would have been nice but this is what I did and it works.
When I bleed my brakes or test these brakes I use a Pipe Vise, typical wood working pipe vice. For this my pipe is about 2 foot long. It allows me to apply the brakes by tightening the vice. I can do this in my garage and it allows me to do the job with no help.   First make sure your brake master cylinder is full of brake fluid.   Tighten the vice and force the slide, where your ball hitch attaches to slide back towards the tires on the trailer.   Jack up one wheel and test it for brakes.   You can apply more or less brake using the pipe vice, I put the vice on an egg crate to support the weight and lower the trailer tongue down till it just keeps the vice from falling off. Otherwise the vice will fall off every time you loosen the pressure.
If you have an electric lockout good for you.   That would be a nice addition.
Once you determine your brakes are working, raise both trailer tires off the ground so you can spin them at the same time.   Now slowly apply your brakes with a little pressure using the pipe vice at the actuator.   Walk back and test each wheel so you know when each starts to work.
Most likely one tire will lock up before the other.   Apply a little more brake pressure and test again. Find out when the 2nd tire locks up or if it does lock up.
Both brakes are supposed to apply equal pressure at the same time. If one is locking up early there is a problem with the brake that is not locking up.   These are disc brakes so they are not adjustable.   You may be able to work it several times and get them to adjust properly or bleed the lines to make sure there is no air in the system on the weak brake side. Air will keep the brakes from working properly.
In my photos you can see where I drilled the Titan for my reverse lock out bolt. There are 3 factory bolts for mounting, these are all in a line, the 4th bolt is the lockout.
I had to have 100% lockout to back a trailer in my driveway. I have to make a 90* turn pushing a little uphill while my truck is on gravel and the trailer is on concrete. If my brake applies the truck just slides sideways on the gravel.   Good Luck with yours.
Edit: The guys are correct about your wires, they will be damaged and fail soon. You can cut a piece of fuel line hose, slice it down the middle so you can slip the wires into it and put a zip tie on to keep your split closed. Slip the hose through your hole in the trailer and your wires will be protected.   Something needs to be there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 4:04pm
Why not just tape up the end of convoluted tubing already on the wire and push the complete tube back over the wires and into the hole? Why make life more difficult than it needs to be? Shouldn't you guys be going out and hording TP......
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 4:28pm
As of yesterday, I understand the HD in Rhinelander is the only place within a 200 mile radius that still has TP! Yesterday at work, we added it up - 40K of the sales were TP, water (limit at 4), sanitizers and cleaning supplies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote C_Heath Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 4:49pm
Thanks a bunch! Will do
MartyMabe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MartyMabe Quote  Post ReplyReply Direct Link To This Post Posted: March-13-2020 at 4:50pm
66 Skylark
93 SN
If you're not living in NC, you're just camping out!
Post Options Post Options   Thanks (1) Thanks(1)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2020 at 2:07pm
More than likely under this https://www.etrailer.com/Accessories-and-Parts/Titan/T4835800183.html
You have one of these
https://www.etrailer.com/Accessories-and-Parts/Titan/T4748800.html
It needs to be wired to your reverse light so when you put your truck in reverse it locks out the braking system.
For this to work you need a 5 pin or 7 pin connector as to incorporate the reverse lock.
The manual (sticking a bolt through) is fine if you don't have to back up any hills, where I live that would be a PITA
When I’m moving my trailer with my tractor I just slide a 1/2” x 4” bolt through the hooks on the front of the actuator that will keep it from sliding and applying pressure when not hooked to the truck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2020 at 2:46pm
Humans went 40K years without TP.
Now it is 1st priority when panic mode hits . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: March-14-2020 at 3:48pm
Toilet paper is so overrated, you need to get one of these things in the link
Last I knew Pete was in the plumbing dept. at the Depot, he's probably an expert on these things
