03 196 Cranking but not Starting |
shea95
Newbie Joined: April-23-2020 Location: NC Status: Offline Points: 2 |
Posted: April-24-2020 at 11:59am |
I have a 2003 Ski Nautique 196 that is cranking but will not start. I have checked the 3 fuses in the main fuse box and they look good, I have replaced all 8 spark plugs, ensured the boat is in neutral, the lanyard is on the kill switch, and charged the battery to a full charge. Not sure where I should go next with this issue. Any recommendations are appreciated.
The fuel pump does run when I turn the electric on. I replaced the fuel pump last year. Also, for background, the boat ran perfectly well about 10 times so far this year. We took about 20 ski sets with no problems prior to having this issue one day when we went to ski. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
If the hpp is cycling then you should be good on the electrical side... I’d be checking the fuel level in the FCC to see if gas is really there or not. Could be a problem on the fuel supply side (lpp/etc).
MrMcD
Grand Poobah Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3734 |
Hook up a Fuel Pressure gauge, it will eliminate almost all fuel supply questions quickly.
Should be able to rent one from your parts store if you don't have one and they are not expensive if you need to buy one. Handy tool if you have a Fuel Injected vehicle to check. Good Luck |
