Holley EFI systems |
Post Reply | Page <12 |
nubf14
Newbie Joined: April-14-2020 Location: Fort Mill SC Status: Offline Points: 16 |
About 50 hours. I can honestly say I will never go back to anything else. I will also say that an ignition upgrade to a Marine (https://performancedistributors.com/product/marine-dui-distributors/) performance distributor had a large boost. Great performance but even better starts/stops etc. I can idle in the 500s now. My old distributor was showing its age so I replaced both at the same time. BTW it was very difficult to find a right rotation which my boat required (special order so special PRICE!!)..
Darrell Sanderlin
1986 CC Martinique Lake Wylie, SC |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11118 |
Back in June you mentioned finding out from Holley whether the fuel pump in the kit (a Holley 12-920) met USCG regs.
I imagine their answer was Yes, here's a link to a Holley page on that pump with those "magic words" included. I'm not sure the wording was there back in June, but it is now link
Oh yea, one last thing.............good job, the naysayers seem to be kinda quiet right about now |
tleed
Senior Member Joined: August-24-2004 Location: United States Status: Offline Points: 267 |
My carbed Yamaha jet ski was problematic all the time until I had a 2-hour conversation with a boat mechanic. She told me it was my gas & that a can of SeaFoam & several hours (!!) of running would fix it up. It did. About that time I bought 10-year-old, 62k-mile Taurus. The elderly original owner must’ve kept the tank full. When I dropped the tank b/c it wouldn’t run, I discovered about 3/8” of solid varnish in the bottom of the tank. I figured it was the solidified precipitate from the alcohol gas. The boat mechanic informed me that carbs hate alcohol gas because that precipitate solidifies in and on the jets and needles & bowls & acts like chewing gum. It glues them in place. Hence the lousy running. If you use your boat regularly, you won’t see a problem, because you keep the gas moving. But seasonally-used engines with carbs, like mowers, snowblowers, and boats are a bad mix with alcohol gas because they allow time for the fuel to evaporate and leave behind the gummy deposits. The boat mechanic told me I wouldn’t believe how many boats she fixed with SeaFoam. Apparently it has just the right ingredients to dissolve the alcohol/varnish deposits. But it won’t work in everything. Fro instance, if the carb is so blocked up fuel can’t flow, SeaFoam can’t clear out the deposits. My jet ski took about 4 hours of continuous running before it cleared up, and it was cantankerous the whole time until it suddenly, “mysteriously” quit all the hesitating. I had beginning-of-season issues with every carbed piece of power equipment I have until I quit using alcohol gas in them. Fuel-injected motors don’t have problems with alcohol gas because the fuel flows under much higher pressure than carbed systems. And FI systems don’t have tiny little orifices that are opened and closed by tiny little parts that can be easily glued in place by a small amount of sticky varnish. Carbs & EFI both have their place. Lawn mowers would be a lot more expensive if they used circuit boards, computer brains, and high-pressure fuel pumps. But there’s a reason why today’s vehicles start & run so easily & get way better gas mileage while putting out a lot more horsepower. I don’t remember my ‘74 Vega very fondly, and I’d love to get EFI on the Chrysler 318 in my ‘74 Southwind. Thomas |
Thomas
1974 Southwind 18 with 318 cubic inches of reverse rotation roller cam "Moparvation" |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2979 |
Sea Foam and other additives always spark a lively discussion...everything from sworn statements regarding miraculous results to “a fool and his money are soon parted”. I have tried various additives over the years and have had good “anecdotal” results from Lucas Fuel Treatment and Klotz Octane Boost. I did try Sea Foam on an older Chevy Suburban once. It blew a lot of white smoke for 5 minutes following treatment, but it was difficult to determine what, if any, improvement there was. And, yes, I agree that ethanol fuels in certain applications is bad ju-ju.
DVskier
Senior Member Joined: September-04-2014 Location: Seneca SC Status: Offline Points: 449 |
I use Sea Foam every year. No fuel problems! I know Pete will chime in about it being “snake oil”. A CC dealer told me to use it and it’s worked for me since 1997. YMMV
MechGaT
Senior Member Joined: March-09-2015 Location: Chattanooga Status: Offline Points: 271 |
If you have never seen Project Farm on YouTube, he does some really good tests. He did one on SeaFoam.
'92 Sport Nautique
AlfaDon
Senior Member Joined: September-18-2011 Location: San Leandro, Ca Status: Offline Points: 407 |
Project Farm is great. Although it's kind of funny the way he delivers information
AlfaDon
Sorry I'm late to the party. What did you use for you low pressure pump? The mechanical lift pump? I'm going to be installing my Holley HP EFI this winter and will be using the Airtex electric marine low pressure pump. Maybe others can respond to this as well. How was the initial learning for the fuel map? Did you run a return line back to the tank? I'm going to be using the Fuel Control Cell and don't know if I can run my return to the FCC, instead of the tank.
DW1
Newbie Joined: March-22-2019 Location: Michigan Status: Offline Points: 21 |
Alfa Don - On a pickup truck application I did not have good luck with (2) Airtex pumps, switched to Delco and all good. May not relate to the low pressure marine pump but use as a data point.
