  New Posts New Posts RSS Feed - Ballast Pump Bypass Switch?
vbatla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vbatla Quote  Post ReplyReply Direct Link To This Post Topic: Ballast Pump Bypass Switch?
    Posted: June-22-2020 at 10:49pm
Are there factory bypass switches for each ballast pump on a 2002 SANTE?
I'm looking to fill the port side only. The dash switch controls all three. I know I could leave the inlet valves closed but I believe that would damage the pumps.
Thanks in advance for any insight/recommendations!
DVskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DVskier Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 11:19pm
planetnautique.com can answer your question.
stepper459 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stepper459 Quote  Post ReplyReply Direct Link To This Post Posted: June-22-2020 at 11:47pm
I kind of doubt it would really hurt the pump to run for a few minutes with the valve closed, but I can't say I've tried it. My '03 has separate switches for each pump.
The tanks will probably also fill mostly just by driving around, so if you open the valve on the port side only, then drive a bit, you might just get the result you're looking for.
