  New Posts New Posts RSS Feed - PCV hose for vacuum check?
DockDoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DockDoc Quote  Post ReplyReply Direct Link To This Post Topic: PCV hose for vacuum check?
    Posted: August-29-2020 at 9:47am
Want to check that my idle mixture is dialed in correctly. Is it reasonable to use the PCV hose (disconnected from PCV) to hook up the gauge for this purpose? No other existing ports that I can find. Guess I could pull the plug on the back of the manifold and put in a brass fitting but given the PCV hose is so accessible figured that may be adequate.
1993 Sport Nautique
PCM 351w, no ProTec
