  New Posts New Posts RSS Feed - Buick V6 231
Buick V6 231
Fritscher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fritscher Quote  Post ReplyReply Direct Link To This Post Topic: Buick V6 231
    Posted: October-06-2020 at 8:43pm
Trying to make use of a Buick 231 that I have in the garage. I would like to use it in a 63 Correct Craft. Does anyone know what drive transmission it would work with? This is my first inboard and I am definitely lost.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 9:38pm
Steve,
Universal Marine marinized the Buick V6. The first was in 63 and used the 198 cu. in.  Then I believe in 65 they went to the 225 cu. in.  Both were mated to the B/W Velvet Drives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fritscher Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 9:56pm
Do you think the B/W Velvet drive will mate to a 231. Very similar to the 225.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fritscher Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 10:48pm
And which velvet drive?
RobertB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobertB Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2020 at 10:53pm
I would "pretend" that it is a chevy.  Pretty sure GM would have used the same trans input shaft specifications since auto transmissions were "probably" the same across the GM brands.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 5:23am
70C
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2020 at 8:48am
Any of the Borg Warner 70 series will work with it as long as you have the right bellhousing to mate the engine to the transmission.
That includes a B/W 70, 71, 70B, 71B, 70C, 71C and later versions labeled as 10-17, along with some others.
You don't have to make believe it's a Chevy either
You do have to have the right flywheel and damper plate for the B/W transmission to mate to though.
Do you have a lot of other marine parts for a 225/231 hanging around like exhaust manifolds, engine mounts, starter, carburetor, distributor, alternator?
Depending on what you might have for parts, it could be a tough job. Wink
