302 rear main seal |
Jdavis
Newbie Joined: June-11-2021 Location: Gadsden, Alabam Status: Offline Points: 4 |
Posted: June-11-2021 at 3:20pm |
I just recently purchased a 76 ski Tique that the previous owner let the engine freeze and crack the block. I think I have found another block but I am having trouble finding the 2 piece rear main seal for a reverse rotation engine. Any suggestions or help would be greatly appreciated.
Is this it? https://www.marineengineparts.com/fel-pro-17746-2-piece-rear-main-seal-ford-302-right-hand-rotation
I question that part number because Summit,O'Reilly's,Jegs,Advance etc all show that it is available but in their description does not list reverse, only marineengineparts state it is.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11118 |
This may be rather silly of me, but the 2 piece rear main seals are smooth and the oil control/wick/helix lines are on the crankshaft so why spend the bucks on a "marine" seal when you can use an automotive 2 piece seal for quite a bit less money?
What year block are you looking at?
If you look it up by part number all except eBay are within a few dollars of each other - eBay is 10 - 11 cheaper.
But if you look up a rear main seal for a 77 ford 302 and come up with a FelPro part number like BS30136 or 2901 for example, it's a bunch cheaper. (edited to add the 2901 seal)
Must be paying for some "marine rubber"
I wonder what the difference between the two is- Felpro is not calling it marine
Using Summit prices for consistency Felpro 30136 not labeled marine...... 18 dollars Felpro 2901 not labeled marine.........27 dollars I think you're paying for that word
Jdavis
Thanks for all the help. I’m going to dig around a little more and see what I can come up with
Must be safe to assume you're looking at a block built sometime before 1983?
Jdavis
Yes I am looking for a pre 1983 block
