Starting trouble |
Author | |||||
JLawski ![]() Newbie ![]() Joined: September-13-2020 Location: Ottawa Status: Offline Points: 4 |
![]() ![]() ![]() ![]() ![]() Posted: July-10-2021 at 6:12pm |
My 2003 196 limited will turnover but not run.I checked off all the usual suspects,fuel in tank,kill switch fuel pump engaging still no luck,any thoughts where to start?
JLawski
MrMcD ![]() Grand Poobah ![]() ![]() Joined: January-28-2014 Location: Folsom, CA Status: Offline Points: 3776 |
Assuming it is fuel injected in 2003, most likely is low or zero fuel pressure. The engine needs Air Fuel and Spark to run so work down the list. A fuel pressure gauge is a nice tool to have to verify fuel pressure.
Checking spark is easy, pull one wire and hook it to a grounded spark plug and see if it sparks when you turn the engine over.
From another thread, here's talk and a picture about checking the fuel pressure:
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11184 |
The only way you should pay any attention at all to this picture in the quote above is if you have a gt40 and the last year of those was 2002 More info would be a good thing
CW757 ![]() Newbie ![]() Joined: August-16-2020 Location: Sunrise Beach Status: Offline Points: 11 |
Relays good back by the ECM?
