  New Posts New Posts RSS Feed - 1986 Correct Craft Martinique Shaft Seal
stm1258 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stm1258 Quote  Post ReplyReply Direct Link To This Post Topic: 1986 Correct Craft Martinique Shaft Seal
    Posted: July-30-2021 at 7:22am
Hi Gang,
You all have been amazing!  Thank you. So the two problems I posted before have been solved.  Windshield broken on left side...local glass shopped fixed it for me for $121.00 and the distributor has been replaced.  Thank you all.
So I have never replaced the shaft seal.  I am looking to order one.  I am guess that size is a 1" shaft seal.  Believe it or not I have the original one on there.
Thanks Gang,
-Sean
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2021 at 7:36am
Sean,
Unless you have a "dripless" prop shaft seal, the seal is actually a rope seal inside the packing gland where the shaft enters the bilge.  Is your's leaking? It should drip some since the rope packing is water lubricated.
Take a look:
Here's a better video on an actual prop shaft:
Post Options Post Options   Thanks (0) Thanks(0)   Quote stm1258 Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2021 at 11:29am
So quick question....what about that rubber hose piece below the coupling where the shaft goes out the boat.  That has never been changed and is looking awfully weak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2021 at 4:57pm
Never a bad idea but, you need to pull the shaft and with a single taper shaft, that can be a job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-30-2021 at 6:15pm
If it's looking awfully weak, you might as well do it now instead of later, otherwise it makes for a big hard to stop leak when it decides to let go.
