  New Posts New Posts RSS Feed - Oily mess out of exhaust
69barri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 69barri Quote  Post ReplyReply Direct Link To This Post Topic: Oily mess out of exhaust
    Posted: October-07-2021 at 3:03pm
I am working on the free 1967 Correct Craft Debonnaire I got. I was able to get the engine to briefly run by pouring a small amount of fuel down the carb. When I did this the starboard exhaust shot a ton of oily muck out of the back. I did find a can of fogging oil in the boat, is it possible the prior owner did too much and that is what I am seeing? Thanks.
1963 Debonnaire Deluxe
1972 Separator Jet Boat
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: October-07-2021 at 3:36pm
I guess it depends on just how oily it is.  And muck, is that from unfiltered raw water, or something else?  Over-fogging will definitely put some black smoke out the pipes, but not enough to make the cooling water really oily.  When you check the engine oil, does it look ok or is it milkshake looking?  If the engine oil looks ok, I'd keep it running for a bit and see if the cooling water cleans up, then check the engine oil again for any signs of water in it.
