  New Posts New Posts RSS Feed - Python 502 Heater Hose Placement
Patton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Patton Quote  Post ReplyReply Direct Link To This Post Topic: Python 502 Heater Hose Placement
    Posted: March-15-2022 at 5:11pm
Hello, I am installing a heater in a boat with a 502 Python. I was just curious if anyone has a 502 Python with a heater installed in the boat? I am looking for how the heater raw water lines are attached to the engine?
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2022 at 10:35am
Is your python raw water cooled?
I think you have a knock sensor on one side of the block and not the other? return fitting.
T off a pressure side line after the thermostat.
If you have fresh water cooled same idea only reminder you have make sure and purge the cooling system.
Make sure and utilize brass fittings and not pvc.
