318 raw water pump |
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
Posted: March-28-2022 at 3:11pm |
Does anyone out there have a good used or new raw water pump for a 318 Chrysler? I do not think there are manufactured any longer. Thanks.
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1194 |
I see couple on eBay $600. I’ve seen in past for $400
But if you have the 2 halves of brass body You can rebuild entire unit with every component for 175 (quality kit) Kit has bearing, seals, impeller, rear bushing Tip, there is a brass washer that goes in cavity first before spring seal, very important |
ScottZ
The pump I have has a slow drip. Where would you get the rebuild kit from? |
67 ski nat
I’ll get the info tonight when I get home
67 ski nat
Steve butrick
850-380-1731 Pump shop in Florida |
67 ski nat
I’ve used 2 kits and rebuilt brass body D-65 double pockets
Very nice kit high quality pieces, USA made I found a old core on eBay $75 rebuilt it works flawlessly. Pay attention to detail and all surfaces smooth |
You may want to be more specific on the year, or reference the pump by its number (or post a pic). Chrysler used a few different ones.
67 ski nat
Good point. I have and refer to the d60 d65 double pocket with 1” in/out and 5/8 shaft. Number should be stamped on pump under pulley where shaft exits
ScottZ
This is the only pump I have ever dealt with for the 318. It uses the Sherwood 09959-K impellers. This one is working but has a small drip off the front half of the pump. |
ScottZ
This engine is out of a 1972 Ski Nautique. I do not have the pump in hand to check the number.
ScottZ
Daryn, I will pass the info. on to the people who have the engine. Thanks for your help.
67 ski nat
Wow. Your pump and engine look super clean and nice
Yes your impeller numbers are correct 9959. Kit comes with those too Sounds like you have a d-65 Sherwood pump. Good luck |
ScottZ
This is a fresh engine. Reman Jasper long block. Previous block was bad.
Orange 72 Promo being rebuilt too. This is the same engine I had in my 71 Ski Nautique.
67 ski nat
Good to know you went jasper
I’ve been looking at many brands too I’ll take another look at jasper Your doing nice job |
