  New Posts New Posts RSS Feed - Starter replacement 94 351
Tomrupp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomrupp Quote  Post ReplyReply Direct Link To This Post Topic: Starter replacement 94 351
    Posted: May-29-2024 at 11:06am
I’m looking to replace my faulty starter. It is not the original. It is the more modern small high torque that I have removed. Casting numbers on the faulty starter are F2SU 11131 AA. No other markings are available. My 351 top of the pulleys turn from Starboard to Port. Normal rotation, correct? Battery is solid and charged. Good connections around. What is the proper replacement? I see prices ranging from $100-$350….
Tom
94 Ski Nautique Open Bow 351 with Carb
95 Double Decker Aqua Patio with 50hp Honda (3 carbs).
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2024 at 11:59am
Yep..............Normal rotation and a good replacement would be an Arco 70200 available at numerous places at a wide range of prices for the same starter. Arco 70125 is the same starter without the little wiring kit and is a little cheaper.
It's pretty easy to find the Arco for about 150ish bucks and free shipping
You can find cheaper stuff but the Arco is a good quality known brand.
PS...........Ford started using the modern high torque permanent magnet little starter in 93 model year engines (being built in 92), so unless you know that it came with the big old style, there's a good chance that it came with the little style originally.
I'll vote for "original starter"
The numbers you found are a Ford engineering number, so it's an original Ford starter or a rebuilt original Wink
The F says it was built in the 90's and the 2 says it was 1992
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tomrupp Quote  Post ReplyReply Direct Link To This Post Posted: May-29-2024 at 2:09pm
Excellent! Thank you Keno.
Tom
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: May-30-2024 at 11:49am
Sponsor site.
www.nautiqueparts.com
