  New Posts New Posts RSS Feed - PCM vs Ford
PCM vs Ford
skibama View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skibama Quote  Post ReplyReply Direct Link To This Post Topic: PCM vs Ford
    Posted: January-05-2007 at 7:29pm
I know this is probably a stupid question to someone in the know.I need to replace my valve cover gaskets on 351 PCM would I be able to go to a parts house and get gaskets for a 351 Ford and be right.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2007 at 8:10pm
correct
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: January-05-2007 at 10:06pm
The only thing different that I have found is the PCM ones have a metal spacer in the hold down holes so when you tighten the cover you don't crush the edge of the valve cover.The generic ones I have bought don't have these and you can over tighten and bend the edge of the cover.Not a problem if your careful.
