351 Rear Main 1 or 2 piece |
Ken-Aus
Newbie Joined: April-13-2004 Location: Australia Status: Offline Points: 7 |
Posted: September-15-2004 at 1:54am |
I have a medium sized leak from the rear main in my 351 PCM. Should I use a 1 piece or 2 piece seal when I fix it? Also can the replacement be done without removing the crank?
Thanks for your help. Ken |
Tim D
Older Ford blocks have a two piece seal. I think around 1980 they have one piece seals. An engine with two piece seals, the crank has directional lines that push oil back to the oil pan. An engine with a one piece seal, the crank is smooth and the seal has the directional lines. One piece seal, you need the marine,for reverse rotation and those I've seen are orange.
Tim D
