  New Posts New Posts RSS Feed - 92’ SNOB - What prop????
  FAQ FAQ  Forum Search Search  Register Register  Login Login
dmoney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dmoney Quote  Post ReplyReply Direct Link To This Post Topic: 92’ SNOB - What prop????
    Posted: September-22-2004 at 5:39pm
I currently use an OJ 14 x 16 three-blade prop. Is there another prop that could reduce the rooster tail and noticeable lip on the wake? I ski 28 off at 34 mph, I would think that the wake should be almost non-existent at that length. Perhaps that vintage hull has this characteristic in the wake. I did, however, have 3 or 4 adults in the boat, so I'm certain weight contributed to the wake. Any other suggestions? Thanks.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: September-23-2004 at 2:31pm
You should probably call ACME and get their oppinion. They are very knowledgable and helpful. I recently purchased a 93 Nautique and ACME recommended their #422 prop (12.5 x 15.5, 4 blade). The original prop was a 14 x 16. As the boat is currently undergoing major reconstruction, I have not yet purchase this prop, so I have no comment on the performance/wake benefits.
I do know that ACME said the #422 will produce the best wake for skiing.
92'NIQUE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 92'NIQUE Quote  Post ReplyReply Direct Link To This Post Posted: September-30-2004 at 12:25am
I have the blue '92 SNOB featured in the "Diary" section. I bought it last week. Pretty sure the prop is the original that came with boat. If there is an aftermarket prop that makes the wake disappear, I'm all ears. Check out the wake in the diary pictures. It could use some flattening. In the meantime, I'll verify what prop is on the boat.
