Stereo & Depth finder on 88 2001 |
Morfoot
Posted: July-30-2007 at 6:57pm |
I've seen several posts and questions on where to put a stereo or depth finder on a 2001. I've included pic's of both. The head unit just clears the stearing column when inserted but looks great there and easy acess to controls. Only thing I wished that I had done was install a rain cover or marine grade unit as I'm on the 2nd one as a nose plunge shorted out the display on the previous one. Did buy a second SONY which made the swap out complete in 5 minutes. I modified the rear seat area on both sides to include a speaker location, cup/ski lube holder, and cubby hole for whatever.
I used a piece of aluminum for the mount bracket for the Depth Gage display and just screwed it in under the dash. |
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
MorFoot, thats where the dealer installed my radio when I bought the boat new works great there. To install the depth sounder, I removed the clock and put it in that guage hole my radio has a clock in it.
behindpropeller
My knee would be gashed if I had a gauge mounted there.....
BuffaloBFN
My knee as well...and my radio is in the back of my glove box
Morfoot
You guys must be Dancing in the seat or big fella's cause my knee NEVER hits it and I'm a 178 lb, 40 yr old, blonde balding guy.
I got too much junk to store to put a radio un the glove box. Wallets, phones, leathermans, hair scruntchies (3 girls) etc,etc,etc. |
behindpropeller
Hey- I am not criticizing your mounting location, it is just a thought. A better location would be next to the driver seat facing straight up if it will fit. I find I'm jumping out of the driver seat a lot since I teach a lot of people skiing stuff. My NMMA panel is all scratched up from my knee brace. Tim |
Morfoot
None taken... I considered putting it in the clock location but I'ma " Keep it original" kinda guy like Pete. I've never had a problem with it and I know a few of us don't want to fool with removing the clock.
BuffaloBFN
I'm 6'2" and about 195...and I have to slip into the seat as it is
PO had a radio stolen from the location shown here...that's where I'm gonna put the finder I have an ugly radio hole in the dash now but it doesn't look like there's anything to steal either LOL |
Mojo
Morfoot,
You're going to have the same problem with that car radio blowing up without a waterproof cover over it... Do yourself a favor and pull it out and throw the cover over it !!! Moj |
05' SV211 TE
Morfoot
Yeah thanks Moj,I probably should or at least make a slip on cover for it. It's garage kept and I throw a couple of towels over it every night if we do mange to go camping. Like I mentioned had a Automotive one installed originally till the nose dive took out the display after the wall of water came up and over the windsheild. Held up for 4 years until that. even then it still worked just didn't know what station was on.
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Just installed a stereo under the Correct Craft emblem on my 85. Am I going to catch grief for cutting the dash? The PO had a stereo under the dash directly below the steering column. I've got scrapes on my right thigh as a result. My 85 BFN is pretty spartan, no glove box and little storage. The rear speakers are set up like Morfoot's.
I've got a 200 watt Dual marine stereo with iPod interface, a set of JBL marine speakers, and a waterproof see through cover. Sounds great. $220 Steve |
'85 BFN '90 BFN White Lake, Michigan |
Munday
Gold Member Joined: August-17-2004 Location: United States Status: Offline Points: 538 |
I put mine in the middle of dash on 92SN.
Like above I removed the hour meter and moved it to a bracket I fab off the alt. all correct wires already there.Then added the depth sounder in that hole. Munday |
