  New Posts New Posts RSS Feed - Prestolite Electronic Module Help.
Morto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Topic: Prestolite Electronic Module Help.
    Posted: July-22-2006 at 5:55am
Hi again everyone, got to the point of re-installing the distributor the other day ('82 Tique PCM351W - the engine was new in '92 and has the screw down cap plus this boat hasn't run for three years) The information I've been able to glean says that after connecting both the electronic mudule wires to the coil (they were connected correctly) I should see 12v at the positive terminal. I have 12v there with neither wire connected and with the black wire connected but as soon as I put the red wire on the voltage drops right down like it's open circuit. It seems to me that it's fried. The wires looked a bit ratty so I snipped them right back to make sure there was no shorting but no help. The biggest problem for me is sourcing the stuff as we live in Brunei. Assuming this thing isn't working does anyone know what the circuit diagram looks like? In other words if I soak it in thinners or paint stripper overnight is it fixable? Remember I can't just run down to SKIDIM. Stuff takes a fortnight to get here if at all!
Thanks.
77stang View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 77stang Quote  Post ReplyReply Direct Link To This Post Posted: July-22-2006 at 2:46pm
what do you want to soak?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 2:20am
The whole thing, I've seen a tutorial on how to rewind a transformer and you soak the thing in paint stripper overnight to remove all the old insulation and stuff. What I really want to know is how to test if it's working before I order another one. If I'm bored one day I might dismantle the old one to see how it works!!
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 8:18am
if you shorten the wires from the dist that was a mistake and you may have just screwed yourself. There should be four wires that go to the coil two from the harness two from the dist.
Don't know what you would want to soak but that's a big waiste of time and won't fix anything to start with. With a 82 that should be a point dist. and have a ballast resistor and you shouldn't see 12v it should be more like 8 or 9v. when conneted and there is no module to mess with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 8:59am
As I mentioned the engine is a '92, and it has a module, a screw down cap and no points. Does anyone know how to test the thing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 9:41am
I took it that you rebuilt the motor in 92. I guess you should have said you replaced the motor with a 1992 motor in 1992.
And it doesan't make any difference it still should have four wires going to the coil. And if your trying to soak the module that's a waiste of time as well because it will not do anything it's not a tranformer to starter with the coil is the only thing close to a transformer and once you remove the case it junk anyway so I don't know what the f**k your trying to do but obviuosly your lost.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 10:00am
I believe he is talking about removing the potting with the stripper and trying to find out which resisor, diode, etc is the problem and replacing it and repotting. I kinda doubt the potting will just disolve and leave a functional board underneath, but since his boat is broken and there is nothing better to do in brunei... anyway I don't have the info you would need to test it much less repair it but in the same situation I could see myself giving it a try if I was sure it was broken...
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 10:25am
92 isn't that the pro-tech ignition system which is a distributorless system? if so then your not going to fix the module it is going to have to be replaced and actually you should throw out the whole system and get a distributor set-up to replace it with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: July-24-2006 at 11:02pm
Alright, alright, the engine receipts say it was new from PCM in '92. I have no idea what actual year the engine was built or what the original set-up was just that the distributor now has a electronic drop in module and retains the ballast etc. JoeinNY is absolutely correct, I'll be bored waiting for a replacement and wonder if it's fixable maybe as a spare. I take it the four wires are two from the distributor, plus the ignition and tach from the harness?
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2006 at 12:14am
Morto, I am a DIY guy myself and I appreciate your initiative. BUT, I have been rewinding coils (not automotive), transformers, and electric motors all of my life and I can tell you from experience - you might as well pour you a new hull as to try to repair that coil. Those things are layer wound on a machine with epoxy insulating varnish. There is no softening up the varnish so don't waste the paint thinner. Even if you could get to the winding to take the data (turn count and wire size) you would never get it all back in the right spot. I doubt that you have access to the necessary wire and insulation.
Sorry to rain on your parade but I didn't want to see you waste the thinner.
Do like me: for times like this you just have to have a 2nd "back-up" boat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Morto Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2006 at 11:05am
You got a spare back-up that floats?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2006 at 11:28am
I would replace the module but would double check and make sure the rest of the wiring is correct and that you have the right voltage. Start with removing the dist leads from the coil leaving the tach/ + lead attached then making sure you have twelve volts on one side of the ballast resistor and about 9 on the other side, then check it again at the coil and make sure it matchs the low side of the BR. Then make sure the leads from the dist are connected right and you get the same reading as the low side of the BR, if not then look for shorts or reversed wires, you may see the voltage drop slightly .5-1v tops. But basicly the module in the dist is plug and play works or doesn't work.
What model and brand Dist is it? can you post some pictures?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2006 at 6:56pm
Yeh Morto, it floats.
tommer12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tommer12 Quote  Post ReplyReply Direct Link To This Post Posted: July-25-2006 at 7:30pm
yup, I have a 92 PCM. I have the Pro-Tec system and its long gone. You will have to go back to distro system and rewire the whole thing. I talked to the dealer the other day and it's about $500 in parts and $500 in labor to switch that system out. sucks....    I'm crossing my fingers that mine is still ok after a few miss fires at start up (see other thread about spark plugs)
cheers. SkiDim sells one, but there is another company they said that has a good handle of this conversion kit called TransPacific
Trans Pacific Distributors
Address:      1941 Walters Court
Fairfield, CA 94533
Phone:      707-426-6670
Email:      N/A
I have called them yet.. but it might be worth a shot
