79SN Rebuild |
Post Reply | Page 12> |
Author | ||
Posted: February-29-2012 at 2:31pm |
I, and many others here, have used US Composites with good results.
Dbat 79SN
Newbie Joined: April-11-2011 Location: Appleton, WI Status: Offline Points: 13 |
Thanks for the input. Now I have the next question...what is the best epoxy to buy? Most of the epoxies that I have found are about $75-$100 a gallon and the one I have found some of the better reviews on is "System Three". Do you have a recomendation and a source?
Dave
Glass CC's were built with polyester resin until 1989. They were built with vinylester from '89-92 (AME4000). Since then, theyve used a vinyl/epoxy blend (AME5000).
Epoxy is the best of the 3 types- it does not absorb water. It is also the strongest, and its easiest to work with (easy to get proper mix ratio between resin and hardener, very low on fumes, no need to add wax to get it to cure, etc). Polyester is the low end in all these regards, vinyl splits the difference between the 2. Pricing per gallon is in the $30 range for poly, $40 for vinyl and $50 for epoxy. For a manufacturer, the difference in cost is significant when youre building a lot of boats (which is why most are built with poly). For a single boat rebuild, the cost difference for the small amount of resin required (10-15 gallons) is only a few hundred bucks... so it seems most people are willing to spend a little extra for the "good stuff" if theyre going to be investing 200+ hrs in labor for such a project. |
My little experence comes from having an attached garage,epoxy does not smell up the house and keeps everyone happy.
79TiqueRebuild
Senior Member Joined: January-21-2009 Location: Kansas City, Mo Status: Offline Points: 238 |
David, From what I remember when doing the research for my 79 sn rebuild, is that polyester is hydroscopic. Water will penetrate it. I used epoxy and was pleased with the results. I'm sure some of the experts will chime in. I am just a hobbyist but I hope that this helps. Monty
Dbat 79SN
I've been reading threads and doing reserch on epoxy vs. polyester resins for stringer replacement and I just don't seem to find a clear answer. The original boat was done with polyester resin, but it appears that there is quite a bit of differing opinions on which one should be used. Can anyone clear this up for me?
Dave
Dave, Have you been looking at the existing threads on stringer replacements? they are an excellent source for what's needed. The big variable will be the moisture content of the wood you are using. What is it? have you checked it with the moisture meter??? The drier it is, the more CPES is sucked in!! |
Keeganino
Grand Poobah Joined: October-27-2009 Location: North Carolina Status: Offline Points: 2063 |
Yep go for the 2 gallon kit. The first coat soaks up a ton. Each successive coat will require less. I did 3 or 4 coats and. Y the last one will barely soak in at all. Then you know it is saturated.
1973 Skier |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
seems that two gallons is about where most guys end up. That left me some do to the inspection panel in the back and the wood pieces up under the bow, I used every drop.
Dbat 79SN
Yes, I am doing the floor as well. Thanks for the quick reply.
Dave
Jllogan
well, coverage depends on what soaks in. I think its maybe a little under a gallon for stringers? Are you doing a wood floor? because mine was like 2 gallons for everything.
Dbat 79SN
I'm just about finished cutting and fitting the new stringers and wat to start priming them with CPES. I can't find any coverage area on any of the websites that sell CPES. Can anyone give me a clue as to how much I need to order to prime the primary and secondary stingers?
Dave
SNobsessed
Tim - Careful posting shop pictures on the web -- I know that would get me fired from my job.
BuffaloBFN
I was sincere with my compliment. I thought your description was excellent...just tech enough with practical info. I used talc and liked it mixed with other stuff so I had to see if you would diss it. It does help a little with the wallet damage. |
Morfoot
Yeah, just a little bit. 10+ years of composite experience for DAL. Guess if they go belly up I can get a job in Orlando building boats. Built up an air/oil seal just yesterday. Guess I need to start taking pics of all this stuff. I'll have to post pictures of a acoustic liner that I repaired but first had to pull parts of 'Tweety' out of. Here's the scoop on: Talc - an inexpensive filler used to extend resin and reduce shrinkage. Talc is a component in many fillers and faring compounds imparting excellent sanding properties where weight is not an issue. I do have a confession though...I'm not that techno savy when it comes to definitions. I do know the uses of each and why you use one or the other but cheated when it comes to short descriptions. Here's the link where I got the info: Resin Fillers and their descriptions of use. |
BuffaloBFN
Nice break-down Tim; almost sounds like it came from someone who's worked with it before?
What's your tech 411 on talc? |
Morfoot
FYI for you guy's that are doing stringer jobs and don't know:
Cab o Sil - fumed silica, used for altering the properties of resin to change thixotropy, add viscosity or increase bond strength. Use to prevent draining from glue joints or on vertical surfaces. Use in combination with other fillers to improve working properties and minimize draining with polyester and epoxy resins. Use with resin or gel coat to make a patching paste or putty. Milled Fibers - fine powdered glass fiber used as a reinforcement to increase mechanical strengths of resins. Add to fillets for increased strength. Use when laminating to fill tight radius. Microspheres/ Microballons - use to extend resin, to reduce weight, shrinkage and sanding effort. Use to fill laminate weave, as a fairing compound and for making fillets. We use all three at the 'Big D' with Microballons probably what we use the most of. We use a resin mixed with 22% ratio of Microballons for a rubstrip on an air oil seal that is attached to the main rotor shaft on a CFM -56 motor. Needless to say it's pretty tuff stuff. ** post edit** Resin and Microballoon mixtures are also used to pot replacement honeycomb core into a damaged portion of aircraft panels, fairings, cowlings etc. It's a normal Boeing repair so if we're using it to fix panels that go over 400 mph I'd say its pretty safe to use to bond stringers to a boat. |
DrStevens
Senior Member Joined: October-15-2011 Location: Columbus, OH Status: Offline Points: 422 |
Dave, I feel your pain on photo posting, you learned it faster than I have'nt, makes me Leary about stringer work when I can hardly post a photo on the site.
Dave, Yes, LVL is an alternate and in fact we have a member who has done it. There's a complete thread with pictures on it. I recommended it and he tried it. It came out great. Don't worry about the secondaries and having to use doug Fir. They are not the main structure so you can use some decent 3/4 pine of any species. Just make sure you CPES all the wood. Try the advanced search feature. (over 6 months old) If you can't find it, I'll see if I can. Sometimes the key words can be tricky. |
Dbat 79SN
Thanks.
Couple more questions: Has anyone used LVL lumber instead of douglas fir for the stringers? The secondary stringer was made of 3/4", can 1 1/2" be used there just like the main stringer? |
Dave
SNobsessed
'Peanut butter' is epoxy resin thickened with a solid like cabosil or milled fiberglass. It is just a filler to create a radius.
Dbat 79SN
In reading other threads there is a reference made to "peanut butter" when setting new stringers in place. At the risk of sounding stupid, I assume that this is not real peanut butter. Can someone let me know what goes between the new stringers and the hull?
Thanks, Dave |
Dave
Keeganino
4.5" Angle grinder with a diamond wheel will take care of most of your cuts. DO yourself a favor first though and gut the boat. Take everything you can out of it but the gauges unless they are not working. You cant cut the whole floor up until the engine is out. My cables were all pretty new so I coiled the controller cables and electric cable up, zip tied them together and hung them from the shifter. I completely pulled the steering system though. The floor cut pics start here in my thread to get an idea what its like.
1973 Skier |
Dbat 79SN
Looks like I am going to have to make time.
Quick first question: "what is the best way to cut out the existing stringers?" I don't want to start by making extra work. |
Dave
charger496
Senior Member Joined: August-06-2010 Location: atlanta, ga Status: Offline Points: 157 |
Just depends on how much spare time and energy you have. I spent the better part of 2 1/2 days a week starting in August and did a floorless water test at the end of November! Then I took my time for 4 months doing the last 40 or so hours in my garage.
Keeganino
Not to be the bearer of bad news but even if you started now you would be hard pressed to be on the water this summer. Scott did one last year pretty fast and got it in the water but there are about 200 hours of labor involved (5 work weeks) and that does not include all the time researching and rounding up materials. I started last January and did not get on the water till the end of August.
Your rot situation is pretty severe and as mentioned before you cant see what will likely be the worst of it. Your in the right place. Read the threads on other restorations. My threadgoes through all the newbie questions as I knew very little. these are good too:
1973 Skier |
79SNbrady
Senior Member Joined: June-26-2008 Location: athens, Tn Status: Offline Points: 229 |
Rebuilding these old boats is a huge undertaking just because of the time thats required to get it all done. I believe someone else added up how many hours its taken for them to finish there boat was like 200hrs. so far i believe i have 24hrs invested with plenty more to go. But best of luck to you! |
"It's just water... not concrete or dirt... so just throw it"
-Parks Bonifay 1979 Ski Nautique - (stringer job completed summer 2012) 2007 236 Team - All White! |
Dbat 79SN
I have to tie up a couple other projects before I get elbows deep into this boat, but it has to happen. Thanks for the encouragement and I will take pictures and keep posting. I am sure I will have many questions going forward. I hope it will see water this summer.
Dave
79SNbrady
Dave,
The real trick is to see how much of the wood is not there around the battery box. About right in that area where your wood is gone, my wood was a tad bit better. But once i went forward from that point there was nothing solid! All ive got to say is pick the engine and start cutting out the floor! Nick |
Dave, I concure! Looking at how far gone that port side main is gone, I now say getting through one more season will be a problem. |
