86 barefoot floor replacement |
Post Reply | Page 123 4> |
Author | |||
JReisch09
Groupie Joined: January-31-2017 Location: Eustis Fl Status: Offline Points: 61 |
Posted: March-25-2017 at 3:54pm |
How did the project go? Thats actually my families old boat, had it for about 12 years. Replaced the old 454 with the 496, my dad works in the marine industry and we were testing out Mercury's smart craft technology for them. First boat I ever learn to handle, spent every summer on that thing in high school everyday, wake boarding and skiing, dates. Was sad to see it go but Dad didn't want to do the floors and sold it to our friend Phil, who you bought it from. If you ever want to sell it let me know, would love to see some pictures if you still have it.
Jon R
1987 Fish Nautique |
shane krausser
Groupie Joined: June-30-2011 Location: Ponte Vedra FL Status: Offline Points: 49 |
Dont forget im running the smartcraft system so theres a ton of different wires. Which one are you speaking of?
86 Barefoot Nautique 496
Is that NM cable under the bow deck or marine duplex? What's it for?
shane krausser
I went ahead and pulled out my front lifting ring backer which was nearly the only piece of wood that was completely dry, go figure!
shane krausser
shane krausser
Hey guys, time for an update i suppose! I finished all of my initial grinding, got all my coosa here and have to order all of my glass and such still. Starting to mark her up and see just where everything is gonna place. Looking forward to meeting some of you at the SJRR, I think i may just have my new camper i can throw a tent in right here!!
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21184 |
Greg, I cant see any of the pics... I can only comment on what I read.
I dont remember the gutter set up you had- remind me! |
BuffaloBFN
Tim, did you forget about my little scrap gutter set-up?
If you didn't see anything wrong other than a potential ski locker on the last page, then I must be way off. His trailer is also interesting under these circumstances. |
Grinding in the garage Tim? By the looks of it I don't think he can even get in the garage
Greg, does this mean that you did all of your grinding in the garage? Ill never make that mistake again! We kept our BFN mobile (on the trailer)- all grinding was done outside. We stripped it to the bare hull and only supported it properly prior to rebuilding the structure... no extra stress cracks appeared in the hull. Perhaps the late 80's boats were a bit thinner than our '79 though? |
eric lavine
leftover sperm costume?
Got it! Yes, following in Tim's footsteps is a fantastic idea. You will not go wrong except, don't use Bilgekote over epoxy!! |
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
ya get that thing blocked. You dont want to mess up that pretty gel.
shane krausser
Tim benjamin
Ben who? |
shane krausser
Buffalo, its a lilttle late for that!! I am following a thread and im doing nearly bens build.
BuffaloBFN
Time out! You really need to do some reading. I'd suggest picking one thread that most closely matches the meathods you are using and try to get very familiar with it.
In a thread like that you'd see that removing one main stringer at a time maintains the hull integrity and prevents stress cracks in the gel. You'd also see that you want your boat properly supported before the floor comes out. |
shane krausser
I figured it would be fixable!! Not a great feeling going through! Yes i am going haz-mat! I was tough for the dirst timr to until fiberglass was up my ass!!! The boat is just supported by the trsiler right now, will block it when getting ready to assemble, so much grinding still left to do!!!
79TiqueRebuild
Senior Member Joined: January-21-2009 Location: Kansas City, Mo Status: Offline Points: 238 |
Shane, I went thru the hull on mine also. My hole was smaller and I put tape on the outside of the boat and filled a layer with thickened epoxy and the built up with glass. No problem.
I'm with you on suiting up while grinding that glass dust gets everywhere. And itch! Looks like your making good progress thanks for taking the time to share with us. Monty |
connorssons
Platinum Member Joined: January-17-2009 Location: Michigan Status: Offline Points: 1414 |
Sorry wont let me upload pic! look at 75 separator rebuild and you can see the cradel the boat sits on. look at pic of boat out side of garage.
connorssons
Do you have the boat supported other than the trailer? here is a pic of my project supported.
Shane,
Are these pictures showing you going on a has-mat job? Sorry, but I always question the "protective" gear you guys seem to use. I just go out and grab the grinder and do it! What are you afraid of? Have you been looking at the MSDS on the resin and glass? |
Jllogan
Ya I did that too in a spot. It can be patched, I did mine with the edge of the grinding disk
shane krausser
shane krausser
shane krausser
here is me getting ready for some grinding today.....I also grinded right through the hull?????? Assuming ill be okay doing glass when rebuilding>> very thin there!!
Jllogan
well, if its just on the underside you can grind out the crack and repair. Its not so bad! Yours could look like mine and be cracked everywhere, I will probably need to regel one day. |
shane krausser
While pulling the plug port and skeggs off i noticed some gel that was cracked on underside of hull where left main seemed to be.
.ill get a pick up, also a few on the gunnels as well. Seems when i pulled th exh tips and one of the skeggs the gel came right off with it??? Im screwed |
I assume youre talking about below the floor? The factory put ribs between the secondary stringer and hull wall every 30" or so. You'd need to remove (or seriously cut into) at least one or 2 to end up with a cavity long enough for a ski. If not refoaming, placing a rib every 12-18" is a better practice... so not a lot of room left under there. |
Make sure you post over on PN and WB the finished LED lights. They will really love them!!! |
