paint shaver pro . is it worth the $ |
Post Reply | Page 12> |
farmer
Senior Member Joined: July-23-2006 Location: United States Status: Offline Points: 442 |
Posted: October-25-2008 at 12:27am |
Watch your fingers.
nautique frk
Platinum Member Joined: February-16-2004 Location: United States Status: Offline Points: 1784 |
Looking good, I can't wait to see it when you get it finished.
farmer
I finally started to apply the epoxy bottom repair. I think I may have made a mistake by grinding off some crystalized fiberglass along the edges. It's going to take a little more work than thought to build them back up but it's do-able.
farmer
pmallinson, I've sent you pictures to your e-mail address. Good luck with your project. You are not alone. Farmer
pmallinson
Newbie Joined: March-28-2007 Location: Ireland Status: Offline Points: 1 |
Hi I'm also needing to strip the pint from my 20' fibre glass boat as its been brush painted by previous owner and looks a mess. I have attacked a small area but good God its thick and well stuck it'll take me a year to do it by hand scraping and sanding. Hence I was also looking at the Marine Shaver but not only do they want $660 but also $150 for P&P to Ireland !! I cannot See your photo's on this posting so could you please email me your home made stripper so I can get some ideas to make my own if need be please. |
Peter Mallinson
Kenmare Southern Ireland www.sheenview.com |
Eric, I should have said Mas and not West. Now you won't need to get out the check book!
eric lavine
Farmer you can clear over anything, except oil
eric lavine
because you wear overalls?
ryan your in the range |
farmer
Why do you think they call me farmer????
79nautique
I've never heard of the water reacting with the epoxy resin. So if I read you right then it's that some uncured/poorly cured section of resin activating with the water causing the issue. Ok I'll by that it must be the presence of extra hydrogen molcules kicking off the resin again creating the pressure, not a chemist but sounds logical. Good line of bullsh*t if it isn't anyway. It's like the sign my dad has in his office, if you can't dazzle them with brillence (sp) baffle them with bullsh*t.
farmer
79nautique,I agree with part of your blister explanation but not all.Yes the water does eventually pa$$ through the gel and cannot readily pa$$ back out again.But the reason has everything to do with what's underneath the gelcoat and not the gelcoat itself.The water collects in voids and dissolves unreacted resin.This forms an acid that attracts more water and eventually builds up enough pressure to cause a blister because like you said,the acid/water will not pa$$ back through.And from what I've read,you're also right about the possibility of blistering over epoxy although to a much lesser extent. Farmer
Guests
Guest |
ohhh yea forgot price point...range from 4800 to 6800....bill marshall did a few eric...
Guests
Guest |
quick question...i know a few people down here on my lake had their entire nautiques re gel koted, different colors some same etc...i never knew you could paint the whole boat...is paint a lot cheaper?...can you paint over existing gel kote?...im getting ideas!!!!
79nautique
that's not true, it will have no barring what so ever whether it will blister or not. Blistering is all in the gel-kote and has nothing to do with the fibergla$$ underneth (sp) it. Water will pa$$ thru the gel and gets' stopped by the fibergla$$ and if it cannot pa$$ back thru the gel-kote then it will blister again. Not trying to be a prick or anything that's just how blisters occur and it can occur on any boat at any time, makes no difference of the material used or processed used to apply the gel-kote. Your best defense is keeping the hull clean and free of wax and not letting it sit in the water for extended periods of time and if you do leave it in the water for extended periods you really need to scrub the hull often to keep it clean from scum and algee that could trap water in the gel-kote. |
farmer
I was thinking of having a sign painter do the stripe and lettering.Can I clear coat over the entire side including the remaining gelcoat?
eric lavine
Anytime i see that word West i think get out the checkbook
Farmer, Since you are putting on the CPES and thickened epoxy the chances of getting blistering are slim if you put the gel back on. Since you are coating with the epoxy, check into the barrier coat addatives. In the WEST system, it's their # 422. I'm going to lean towards putting the gel back on.
Great job so far. Love how you made the removal tool with the angle grinder! |
eric lavine
alot also depends what the owner wants and how he will take care of the boat over the next 10 or so years.. im with you for durability BD i would use the Imron.
For looks i would go bc/cc, that gives you the oppertunity to stripe her and clear over decals if any. remember there are cheap clears and good clears. cars hold up well in the sun as will a boat I vote no on the gel coat |
boat dr
Eric, I gotta go with the Imron,have one white and one yellow. The yellow is ten years old and still shines and looks as good as day one, and has had a lot of salt water time.
The down side about that stuff is it's bad ,or should I say not "GREEN".Harmful to anything that eats,breaths or walks, but any two part epoxy coatings are......boat dr |
eric lavine
Im not a big fan of Gel coat either, Gel coat has a purpose, it is used as a mold release when the hull is manufactured.
they make amazing products to paint boats, my first choice would be base coat clear coat,The clears nowadays have UV protecters in it and holds up well. anything that says marine on it is twice the price for the same product. Allgrip great but so is the price, Imron is also very durable..... anyone else?.... |
79nautique
If your going to paint it and not use gel-kote then you won't have any blisters again, but if you spray gel-kote back on then you might get blisters again at some point.
farmer
I am taking off the gel only to the waterline.The rest of the gel should clean up much nicer than I could do with my limited talent.My plan is to build coats of epoxy starting with CPES and finishing with epoxy mixed with thickeners to fair the surface.I have a friend with a spray booth who will shoot the epoxy with awlgrip or something similar. No more blisters.I will hide most of the seam under the stripe along the side.Does anyone see any problems with this plan? I am open to suggestions. Farmer
eric lavine
Farmer, what's next?
Guests
Guest |
cool thing to do!!!....pretty neat tool
farmer
Why is everybody always trying to rain on my parade? Farmer
eric lavine
hey farmer 2 hours to strip..........20000 to paint lol eric nice job
2_Nautiques
Senior Member Joined: March-22-2006 Location: United States Status: Offline Points: 251 |
Farmer, nice job making the tool, Good ole Yankee Ingenuity I don't know how you guy down south do it. I use the winter to get caught up on all my "Honey Dos" before I get the boats out. Once the boats are out, no more "honey dos"
79nautique
Gary we'll let you know how the water was later today, mid to upper 70's and John's new hot rod should be fun.
farmer
jbear,winter gives us time to work on our boats and not feel bad that we're not out on the water. farmer
jbear
Wow, I agree, that is a scary lookin picture!
Looks like lotsa work. BTW: what is that ugly looking white stuff along the driveway? Looks nasty as well. john PS to 79: See you at the ramp. |
"Loud pipes save lives"
